2 heater problems #1013792 11/27/10 02:54 PM
CAskier Offline OP
97 TJ Sahara. Here are the problems:
1. I've got coolant leaking from the floor vents on both sides. Replaced the heater core 2 years ago, so it better not be leaking again. Any ideas?
2. Defrost doesn't work. Not sure how the heater operates, but when I turn it to defrost, I hear a bang, like a flap has closed and I hear the pressure of the air trying to flow, but it can't get out. Hard to explain. All other settings (blow straight out, and floor vents) seem to work fine.
Re: 2 heater problems [Re: CAskier] #1013793 11/27/10 07:40 PM
4x4Wire Offline
Sounds like you have a vacuum leak. Check your vacuum hoses around the firewall/heater area.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: 2 heater problems [Re: CAskier] #1013794 11/28/10 02:52 PM
MartySoCal Offline
1) make sure that the heater hoses are not leaking at the heater core, otherwise, the core is bad.
2) There's a plastic lever for the air door on the left side of the HVAC housing that breaks. You used to be able to buy just the lever, but I think it superceded to a whole door/lever assembly. If you find it broken, the part that broke off will be inside the door in the housing. A long drywall screw will thread inside the broken part so you can extract the broken piece. If the new part is only available as a complete door, the housing will have to be removed and the case halfs split.
Hope this helps!
P.S. If all you lost was vacuum, but the housing was still operating properly, the system would default to the full defrost position, full heat as a safety measure.
Re: 2 heater problems [Re: MartySoCal] #1013795 12/02/10 05:23 AM
CAskier Offline OP
ok, I checked the two hoses that go into the heater core at the firewall, they are fine. I noticed that about a foot below those two hoses, on the firewall, there is a connection for a hose. Water/coolant is leaking out of that. Should there be a hose on there? Where would it go? I don't see anything disconnected.
Re: 2 heater problems [Re: CAskier] #1013796 12/02/10 05:28 AM
4x4Wire Offline
Sounds like that is a condensation drain tube and should be fine as is.
There should be a vacuum line running into the firewall. If that is in place and no leaks, follow Marty's steps about internal to the heater core.
John Stewart
Editor - 4x4Voice
Re: 2 heater problems [Re: 4x4Wire] #1013797 12/02/10 05:40 AM
CAskier Offline OP
Not seeing the vacuum line. How big is it and where should it be?
Re: 2 heater problems [Re: CAskier] #1013798 12/02/10 03:03 PM
BigJim Offline
I havn't looked at my late model Jeep but all before have had the vac line from the back of the intake manifold almost directly straight into the firewall.. So my point is that line isn't near the heater hoses. It is pretty easy to see if you look at the entire firewall.
If you don't see the line then there should AT LEAST be a nipple on the firewall where the line has fell off..
Re: 2 heater problems [Re: CAskier] #1013799 12/05/10 03:03 PM
MartySoCal Offline
If coolant is leaking out of the condensation drain tube, and the heater hose connections are tight, the core is bad.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6222 MB (Peak: 0.7048 MB) Data Comp: Off Server Time: 2026-06-07 04:34:57 UTC
