Uh oh, no oil pressure after wrenching #1014069 11/30/10 07:48 AM
Liquid_force Offline OP
Working sporadically over the last 2-1/2 weeks I replaced valve stem seals, timing belt and assoc. parts, plugs and wires.
This is the SOHC 3.5l FWIW.
Upon reassembly I fired it up. It ran relatively smoothly, but there was a lot of valve noise.
It always had a little valve noise, but this seemed even more obvious than usual.
I took a look at the gauges and noticed the oil pressure gauge at zero. Shut down.
Checked the connector at the sender and was connected.
I'm at a loss, although that's a state I often find myself in when I open the tool box.
Any ideas?
Dec '07 purchase -- '99 Sport LTD 3.5L SOHC - 139k, now 188k
'95 Montero LS 206k+ (traded)
New DD - '99 Taurus SHO 95k - V8's are fun <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Uh oh, no oil pressure after wrenching [Re: Liquid_force] #1014070 11/30/10 07:18 PM
You didn't mention it so I figure I'd ask, did you check the oil level?
Re: Uh oh, no oil pressure after wrenching [Re: off-roader] #1014071 11/30/10 07:42 PM
Yes, before and after starting it.
It's in the safe area, fairly clean.
Re: Uh oh, no oil pressure after wrenching [Re: Liquid_force] #1014072 11/30/10 08:58 PM
MI_Mitsu Offline
I dont know the 3.5 at all, but i would assume a fairly easy way to tell whats going on is to pull either the oil pressure sender, or the line if it's a manual gauge off the block. Crank the motor by hand or crank it with the starter (coil disconnected) just to turn the oil pump a few times. If you get oil out the port, your oil pump is working OK (or barely) and perhaps it's your gauge that's bad. You may want to have a secondary back up test gauge to see if you get the same reading as the dash gauge.
If you get no oil out the port, i'd suspect a bad oil pump
<img src="/forums/images/graemlins/scared.gif" alt="" />
And yes, this could get a little messy. A 2nd pair of hands with a catch container or rag would be helpful!
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: Uh oh, no oil pressure after wrenching [Re: MI_Mitsu] #1014073 11/30/10 11:13 PM
Test the gauge by grounding the sender wire and see if the gauge pegs high with the ignition on. DON'T leave this ground connected long, just long enough to see the gauge rushing to the peg. Control current with the ignition switch. A mechanical test gauge with a BTP thread into the sender hole and cranking the motor with a starter button hooked to battery cable at starter and starter solenoid wire spade connector will let you lie under the truck and see the gauge as you crank with the ignition and truck electrical system off. Did you drain and change the oil?
Re: Uh oh, no oil pressure after wrenching [Re: fasteddy] #1014074 12/01/10 12:37 AM
Didn't drain oil before test start.
the electrical test will be easy. Mechanical not so much, but i'll work it out if i need to.
Thanks for the help.
Re: Uh oh, no oil pressure after wrenching [Re: Liquid_force] #1014075 12/01/10 02:28 AM
Depending on how long it sat, the oil may have drained back to the pan and the pump may have lost prime. It will reprime (unless it's got too much wear), just slowly, since it's designed to pump oil, not air, and it has to move air to get the oil to suck up to the pump again.
You can do mech without a gauge - just remove the sender and block the hole with a finger and crank it and see if you irresistable pressure. You should not be able to hold cold oil pressure with your finger.
Re: Uh oh, no oil pressure after wrenching [Re: fasteddy] #1014076 12/01/10 03:53 AM
Thanks again for the help.
A bit of a false alarm.
A closer look at the sender connection revealed a corroded/broken wire. I replaced the terminal, and I did go ahead and ground it to make sure the gauge was good. It was.
It showed good pressure after an oil change.
Still not running quite right though. Wondering if I didn't mix up a couple plug wires, but it's never that simple.
Re: Uh oh, no oil pressure after wrenching [Re: Liquid_force] #1014077 12/01/10 07:20 PM
firing order is 123456
Re: Uh oh, no oil pressure after wrenching [Re: Liquid_force] #1014078 12/06/10 01:29 AM
Anothe follow up for those of us less "seasoned" home mechaics.
Wires/igniters were fine.
It continued not sounding quite right, but did evenually start running like I expected it to.
I guess just sitting for close to a month and having the valve train basically void of any oil led to it taking some time to get re-lubricated after running. Although I did wet it down with my oil squirt can before I reassembled it.
Anyway - it's back on the road. I've put about 100 mi on it and I'm convinced I can safely turn it back over to the wife.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6418 MB (Peak: 0.7675 MB) Data Comp: Off Server Time: 2026-06-20 17:45:18 UTC
