Power Steering Gearbox question #1014082 11/30/10 06:21 PM
toyomorph Offline OP
Hey all, how are you all doing after the feast? I'm just a little heavier.... (oh no)...
I have a 93 4x reg cab 22re. It has manual steering from factory. I found a good deal on a power steering gearbox. I already have the pump and brackets to install. It might be some time though till I get to it, and it's colder than a well diggers backside right now. So, is there something I should do to preserve the gearbox till I get to it? Or is it cool to store it for a short time emptied of fluid?
Thanks.
canyon country explorer
1993 4x PUP
Re: Power Steering Gearbox question [Re: toyomorph] #1014083 12/01/10 01:52 PM
missouriman Offline
it will be fine.
Re: Power Steering Gearbox question [Re: toyomorph] #1014084 12/04/10 01:17 AM
KB1 Offline
Good eve!!
Turned my 2wd '94 into p/s and found one thing you didn't mention. May not matter on 4wd but I'll bet it does.
You will also need the steering shaft from the box's end to the firewall. They are different in the fact that the box has a different length shaft going toward the firewall. You will need to go back to the boneyard and get that shaft to match. Should give it to you or swap. Mine did.
Re: Power Steering Gearbox question [Re: KB1] #1014085 12/04/10 11:57 PM
Thanks for the tip KB1. Looking at the exploded parts breakdown it does indeed look like the two steering gearboxes are not the same dimensions.
1993 4x PUP
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5998 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-06-10 01:33:20 UTC
