montero ls or sr ? #1014131 12/01/10 05:17 AM
belijose Offline OP
hello, Is it possible to find a rear locking differential on a 95 Montero ls ? I saw one today and it has a hose going into the differential on the left( drivers side) I have read that only the sr's came with the lockers. did all of them came with it ? thanks
1989 Dodge Raider v6 3.0 L, MT.
Re: montero ls or sr ? [Re: belijose] #1014132 12/01/10 07:54 AM
94-96 (& possibly 97's) SR's all came with lockers. LS' didn't.
Doesn't mean someone didn't swap in an SR rear end to get the locker. May also be a breather hose (dont recall what side they're on).
Re: montero ls or sr ? [Re: belijose] #1014133 12/01/10 03:15 PM
StockRaider Offline
What you saw was most likely a differential breather tube. Trace it back and if the line goes to the tube in the frame then its not a locker line.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: montero ls or sr ? [Re: off-roader] #1014134 12/03/10 01:27 AM
93montero_sr Offline
My 93 has one.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: montero ls or sr ? [Re: 93montero_sr] #1014135 12/03/10 05:07 AM
My 93 has one.
Good point. I know some of the 93/92 SRs had them but wasn't sure if they all came with them... Anyone know?
Re: montero ls or sr ? [Re: off-roader] #1014136 12/03/10 07:21 PM
Diff breather most likely.. It is easy as pie to swap in a factory locked rear end though so if you happen to find a smoking deal on an LS then go for it. You can always just swap out the third member and an axle with an locked SRs too. <img src="/forums/images/graemlins/cheers.gif" alt="" />
The entire locked rear end from an SR averages about $450
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6159 MB (Peak: 0.6856 MB) Data Comp: Off Server Time: 2026-10-22 07:39:59 UTC
