1995 T100 SR5 4x4 Tail light question
#1014332
12/03/10 01:37 PM
My truck has 198,000 and runs great but yesterday the right turn signal light on the dash was lit when I started the truck and never went out. When I turned the left signal on it worked fine but the right signal would not flash. I looked at the lights and the top bulb stays lit, wont flash when I signal a right turn? Later in the day I started it and it went away, everything normal. Today back to staying lit?? What does this mean?? Thanks..
Re: 1995 T100 SR5 4x4 Tail light question
[Re: toyotakev]
#1014333
12/04/10 05:01 PM
Do you have a trailer light adapter harness hooked up? If so, take it out and check yer lights again. <img src="/forums/images/graemlins/wink.gif" alt="" />
Basically...you have a short in the turn signal system. Could be from corrosion in the socket or in the harness adapter. <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: BamZipPow]
#1014334
12/05/10 02:12 PM
I do have the optional tow package on the truck the the connector does not have a cover on it.. I will check the wiring harness.. thanks!
[Re: toyotakev]
#1014335
12/08/10 01:09 AM
Snipped the wire from the trailer hitch and problem is fixed, everything working great! Thanks a ton!
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6007 MB (Peak: 0.6562 MB) Data Comp: Off Server Time: 2026-05-29 22:27:50 UTCValid HTML 5 and Valid CSS
