2.2L diesel , wil it work in 85 & up w/ 22r, 22re // #1014373 12/04/10 03:57 AM
moto629 Offline OP
i'm looking for a home for a very nice running 82 2.2L toyota diesel, the truck frame & body are rusted out beyond repair, i've got a few 85 to 92 trucks w/ 22re that need motors, from what i understand, they will bolt right up , the exhaust is on the other side, and if you use it in a 4x4 you have to get a oil pan from a 4x4 diesel or modify the original for clearance- these diesels are only about 65 horse and 22r is the 90 range, has anyone done this ??
Re: 2.2L diesel , wil it work in 85 & up w/ 22r, 22re // [Re: moto629] #1014374 12/05/10 06:49 AM
A
Andy87 Offline
With the right bellhousing and oil pan (as you mentioned), among other odds and ends, it will work... but will probably be very underpowered in anything but a 2wd single cab. Check www.toyotadiesel.com for lots more info.
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
PHP: 7.4.33 Page Time: 0.043s Queries: 15 (0.040s) Memory: 0.5861 MB (Peak: 0.6334 MB) Data Comp: Off Server Time: 2026-11-03 11:39:02 UTC
