Rock Auto Head Gasket Question #1014424 12/04/10 11:54 PM
toyomorph Offline OP
Hi. Is this one of the Rock Auto Head Gaskets that have the infamous "slipper plate"?
Are these any good?
canyon country explorer
1993 4x PUP
Re: Rock Auto Head Gasket Question [Re: toyomorph] #1014425 12/07/10 12:35 PM
Well, I guess nobody on this forum has used or knows anything about a rock head gasket. (even if they got it from EB?)
1993 4x PUP
Re: Rock Auto Head Gasket Question [Re: toyomorph] #1014426 12/08/10 02:40 AM
CJM Offline
I have used 2 .. both failed !! replace with OE , and both trucks are still running today
OE the only way to go
83 Trekker SR5
NEW Trekker forum
Re: Rock Auto Head Gasket Question [Re: toyomorph] #1014427 12/08/10 03:59 AM
A
ak92toyota Offline
yep those are junk oe is the best
Re: Rock Auto Head Gasket Question [Re: ak92toyota] #1014428 12/09/10 12:30 PM
Thank you for the replies, much appreciated.
1993 4x PUP
Re: Rock Auto Head Gasket Question [Re: toyomorph] #1014429 12/12/10 02:45 PM
engnbldr Offline
>>>*Sorry I have been gone a bit, I had to have some surgery to fix a little problem, all fine now it appears.
*Actually, that is not a "Rock Auto" product, it is a RockProducts gasket, different company.
Neither company makes gaskets, they pack them into kits.
I personally sat in on the conference a bit over a decade ago, many of us were working on solving the problems with the Honda CVCC and other makes like the Neon that were eating head gaskets.
The steel facing was the solution as it allows the aluminum head to slip during warmup, and that technology is in use by many other suppliers, including Toyota. The Graphite impregnated core is identical to that now used by nearly all manufacturers, none of them can use Asbestos anymore as it has been banned.
The term "Slipperplate" was mentioned, I liked it and registered it under my own company. Sneaky I know, it's called marketing.
The design is in use in thousands and tens of thousands of Japanese import engines with success. In fact "Rock Auto" also uses similar technology, and not a thing wrong with that product, either.
If in doubt, buy the Toyota product. I happen to know who makes them.
Most of the time when I see a gasket fail on any engine, I can look at it, and the surrounding metal on the head and the block, and see the reason. Then we can often trace right back to the cause.......*EB
*Beats the he** outa me!....*LOL**...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6086 MB (Peak: 0.6778 MB) Data Comp: Off Server Time: 2026-06-21 00:07:12 UTC
