4D56T Automatic Flywheel === Edit=== Flex plate
#1014482
12/05/10 08:16 PM
Hi again folks..
My missing tooth anoyance of the last 3.5 yrs finally cooked the bendix (or that is my guess)
I think I have one more "start" left in it to get to the garage.
Now I have a post into the buy and sell for another (and maybe someone knows a source in AB or BC) but this post is to ask on the plausibility of just rotating the fly wheel..
I know the best remedy is to replace the plate. That is understood, but the engine always seems to stop at the same group of missing teeth. This leads me to _speculate_ that if the plate were to be rotated a full bolt hole set or so the problem would go away for a time being.
Does any one know if the plate is symmetrical in its bolt pattern?
Also is there any method to repair the wheel.. I am guessing no but I thought I would ask.
Thanx
97 Prado (LC 90 series) JDM import 2020 --- 2000 Galloper II SWB under offer from Korea 88 Mits Pajero LWB 185000Km 2.5TD JDM import (SOLD)
Re: 4D56T Automatic Flywheel === Edit=== Flex plate
[Re: bill_bly_ca]
#1014483
12/07/10 06:24 PM
After contacting a couple parts suppliers it looks like I need a Flex plate not the fly wheel.. My bad - Nomenclature is everything..
So I have one offered as a replacement gear ring @ $280 and one as a flex plate assembly at $575.
Can anyone look up the part number of the actual thing (for fear of using the wrong word) that the starter meshes to upon starting on a L049G-3016784 Chassis?
Thanx
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5882 MB (Peak: 0.6368 MB) Data Comp: Off Server Time: 2026-05-27 17:04:02 UTCValid HTML 5 and Valid CSS
