Re: 2nd gen clutch replacement is rapidly becoming a nightmare :/ [Re: OOP'S] #1014616 12/08/10 03:49 PM
gueroblanco Offline OP
sho nuff... here is the beast <img src="/forums/images/graemlins/angry.gif" alt="" /> what a f!@#ing pain! It wouldn't have been so bad if the guy who owned it before me had taken the time to install the alarm and stuff correctly. he just zip tied wires to anything he could and tucked them over and around everything under there. grrrr! anyway heres some pics for others i noticed who may be experiencing this.
no good...
'95 runner 3vze/r150f
Re: 2nd gen clutch replacement is rapidly becoming a nightmare :/ [Re: gueroblanco] #1014617 12/08/10 05:11 PM
OOP'S Offline
Check the firewall also, sometimes they also crack.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 2nd gen clutch replacement is rapidly becoming a nightmare :/ [Re: Greg_Canada] #1014618 12/08/10 07:44 PM
if my m.c. isn't leaking it should be good huh?
Re: 2nd gen clutch replacement is rapidly becoming a nightmare :/ [Re: gueroblanco] #1014619 12/09/10 03:52 AM
kewlynx Offline
Don't forget our Toyota section at the top here; that's where the tech writeups live <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.4x4wire.com/toyota/maintenance/clutchmaintenance/
WTG; that's probably the most jacked up bracket I've seen posted to date.
**ubi apis- ibi salus**
Re: 2nd gen clutch replacement is rapidly becoming a nightmare :/ [Re: kewlynx] #1014620 12/09/10 03:37 PM
ok yesterday, i dug my welder out from alongside my runner in the garage. (doing this kind of operation in a single car garage is great) <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> i clamped the crack together and proceeded to weld the crack itself together and then i laid a blanket bead up in throughout the inside corner of that whole weak area. i grinded the back side that meets the firewall to be sure there would be no issues there. I pulled the m.c. and discovered an 1/8" of sediment in the bottom of the reservoir so i cleaned that out. then i reinstalled it and bled the heck out of the system using about 20 psi blown through the little breather hole in the cap of the reservoir. i put about a pint through that line before i finally closed the screw. after putting everything back together, i was relieved to hear reverse barely grind a couple of teeth before going into gear. I think my problem was a combo of air in the line and the cracked bracket. i still think there is a little issue with my tranny hence the slight grinding going into reverse and still not really wanting to go into gear unless rpms match road speed? at least the clutch disengages. hopefully i can deal with the tranny later when i have more time and $$$. Thanks for all your suggestions fols <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2nd gen clutch replacement is rapidly becoming a nightmare :/ [Re: gueroblanco] #1014621 12/09/10 05:45 PM
Staceman Offline
You don't run synthetic, or GL5 gear oil in the transmission, do you?
Congrats, BTW.
Re: 2nd gen clutch replacement is rapidly becoming a nightmare :/ [Re: Staceman] #1014622 12/10/10 01:49 PM
to be honest, i bought this thing off of a city kid in april <img src="/forums/images/graemlins/lol.gif" alt="" /> , so i have no idea what he has done to it. I haven't added to or changed the gear oil so i'm assuming it's regular stuff in there.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6273 MB (Peak: 0.7347 MB) Data Comp: Off Server Time: 2026-10-21 22:03:54 UTC
