brake rotors
#1015070
12/12/10 06:34 PM
I found a set of drilled and slotted rear disc at the salvage yard to match my fronts. However I have not done my rear SR axle swap YET. The rotors come from a 93LS and the axle will most likely come from a 95 or 96 SR can somebody tell me if there the same rotors? It might be a while before I do the axle swap and I know the rotor will not last. I checked Rock auto to compare the part numbers and they are different but I was hoping somebody knew for sure.
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.004s) Memory: 0.5836 MB (Peak: 0.6240 MB) Data Comp: Off Server Time: 2026-06-07 10:36:33 UTCValid HTML 5 and Valid CSS
