Just did a lot of work - now a water leak, front side #1015198 12/13/10 07:23 PM
Liquid_force Offline OP
I recently replaced VSS, TB, WP, and a few other items on the '99 SOHC 3.5l.
After a week or so of driving it I smelled and saw a water leak. Underneath there are green tracks coming down the oil filter. I haven't been able to trace it to a specific location. I'm HOPING it's something besides the water pump/gasket/o-ring, but I don't see anything obvious.
I didn't replace the o-ring b/c the one supplied with the pump was not close to the right one. I did remove the old one. It was still pliable. I cleaned the groove, oiled it. Thought it would be ok.
It's a sizable leak. The reservoir will go from full to add in no more than a couple days - maybe an hour or two of drive time.
Anybody dealt with a similar leak, or have a method of determining the source w/o just tearing back into it?
Even if I tear back into it, if it's dry, will I be able to find the source?
I'm leery of the new wp as a whole. It's the GMB pump that req'd grinding on the surface for the TB to clear.
Dec '07 purchase -- '99 Sport LTD 3.5L SOHC - 139k, now 188k
'95 Montero LS 206k+ (traded)
New DD - '99 Taurus SHO 95k - V8's are fun <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Just did a lot of work - now a water leak, front side [Re: Liquid_force] #1015199 12/13/10 07:56 PM
StockRaider Offline
I hope you didn't literally use oil. If so, the O-ring probably swelled up and broke seal. I normally use waterpump RTV on the O-ring back there.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Just did a lot of work - now a water leak, front side [Re: Liquid_force] #1015200 12/13/10 09:20 PM
I always coated o-rings w/clean engine oil before installation.
New or reusing.
Re: Just did a lot of work - now a water leak, front side [Re: Liquid_force] #1015201 12/14/10 06:19 AM
StockRaider Offline
Oil will cause rubber to swell and break down. I would begin checking there.
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.026s Queries: 15 (0.021s) Memory: 0.6027 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-11-20 00:15:22 UTC
