91 LS Cargo Door locked and cant be opened #1015450 12/17/10 12:19 AM
Grandpa Bill Offline OP
I went to get some stuff out of the back of my 91 LS and the door wouldn't unlock, at all. With the power lock or the key! Any ideas on getting freed up. I'm not sure if it's the power lock or the manual mechanism. I don't really want to tear up the panel to get to things. Any ideas?
Bill Mattson, Certified Old Guy
Monty-less (right now)
Laura Mattson, Certifiable
Get in, sit down, BUCKLE UP, shut up and HANG ON!!!
Re: 91 LS Cargo Door locked and cant be opened [Re: Grandpa Bill] #1015451 12/17/10 02:07 AM
RECON45 Offline
Just checking did you work the inside door handle and try sliding the lock on the inside? The rear door card comes off super easy and is difficult to mess up. Just a philips screw driver, just be mindful of the nasty tar stuff around the edges of the door card. From there you will get a better idea if there is something wrong with the lock mech., linkages, or etc...
Re: 91 LS Cargo Door locked and cant be opened [Re: RECON45] #1015452 12/17/10 09:12 PM
dadrab Offline
True, but can you get it off with the door closed?
with awesome audio.
Re: 91 LS Cargo Door locked and cant be opened [Re: Grandpa Bill] #1015453 12/18/10 12:07 AM
redbull Offline
My Gen 2 was the same way until I sprayed some lube up the small hole under the handle.
Re: 91 LS Cargo Door locked and cant be opened [Re: redbull] #1015454 12/19/10 03:08 AM
3
3esso Offline
I Had the same Problem some time ago
did the same solution as above <img src="/forums/images/graemlins/smile.gif" alt="" />
go the the handle and look underneath you should see a small opening that the white handle goes to, just spray some Lube into it or a penetrating oil (WD-40)
should fix it
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Re: 91 LS Cargo Door locked and cant be opened [Re: 3esso] #1015455 12/19/10 04:08 AM
...a penetrating oil (WD-40)...
Fwiw as an aside... it's been discussed here ad nauseum and the conclusion was IIRC, WD40 is a poor, (i.e. not very effective) penetrating oil and you're much better off using a different product.
What WD40 is good for is to displace water which it was originally designed to do, hence it's name WD='Water Displacement'.
Re: 91 LS Cargo Door locked and cant be opened [Re: off-roader] #1015456 12/19/10 05:36 AM
Kevin C Offline
Penetrating oil matters if your removing a stuck fastener. As far as a general lube for a door latch internals, my experiance with WD 40 has been good.
Kevin
Re: 91 LS Cargo Door locked and cant be opened [Re: Kevin C] #1015457 12/19/10 08:47 AM
3
300D50 Offline
Lithium grease or permatex silicone grease work good on door linkages, the silicone stays put forever though, so be careful where it gets smeared if you use it. It's murder to get off of glass as well.
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: 91 LS Cargo Door locked and cant be opened [Re: 300D50] #1015458 12/19/10 09:06 AM
Kevin C Offline
Great for the parts you can get to... I use spray lube on the hidden parts or the parts that are hidden until you take them out.
Re: 91 LS Cargo Door locked and cant be opened [Re: Grandpa Bill] #1015459 12/19/10 09:11 PM
I was wondering what happened to ya, Bill. I missed the post a couple of months ago about selling your Montero. Before that, it looks like it's been a couple of years since you've been on here. Hope things go well for you.
Are you still planning on moving?
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6358 MB (Peak: 0.7437 MB) Data Comp: Off Server Time: 2026-05-29 15:05:00 UTC
