ford 4.6 swap? #1015740 12/21/10 05:51 AM
RauchOffRoad Offline OP
Anyone done a 4.6 swap? Just curious, the heads might be too big I know the one my mustang is massive.
Re: ford 4.6 swap? [Re: RauchOffRoad] #1015741 12/21/10 03:26 PM
G
Greg_Canada Offline
Wow haven't seen you here in years.
That motor is absolutely massive... just pulled one out of a mark VIII for my cousins project truck... it will be very, very tight... and sheetmetal will probably need to be "persuaded" <img src="/forums/images/graemlins/lol.gif" alt="" />
Haven't seen one done. Might want to check pirate.
89 4Runner
Re: ford 4.6 swap? [Re: Greg_Canada] #1015742 12/23/10 02:00 AM
bkg Offline
I'm going to say that it will never clear the steering shaft - too wide.
Brian K. Gallus
Re: ford 4.6 swap? [Re: bkg] #1015743 12/23/10 07:11 AM
Yea the heads are massive on that thing but damn its a sweet motor. Power all over the place.
Re: ford 4.6 swap? [Re: RauchOffRoad] #1015744 12/23/10 05:29 PM
OOP'S Offline
I do not know a lot about Ford engines and the differencs in them. I had a friend that swapped in a 5.0 in an 83 and it was a tight fit, but he did it. There use to be a write-up on it in the tech section on PBB. I will look and see if I can find the link.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: ford 4.6 swap? [Re: OOP'S] #1015745 12/23/10 05:35 PM
OOP'S Offline
Not a lot of info but here is the link;
http://www.pirate4x4.com/tech/Engine/index2.html#Steering
David Fritzsche
Roseville, CA
Re: ford 4.6 swap? [Re: OOP'S] #1015746 12/23/10 05:50 PM
Yea I'm batting around the idea of picking up a 3.0 truck when in Texas this spring and doing a 5.0 swap. I'd rather keep the toyota tranny etc. Is there a bell housing that will work for this?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6152 MB (Peak: 0.6891 MB) Data Comp: Off Server Time: 2026-05-29 17:16:23 UTC
