Clearance available for drivetrain lift
#1016263
12/27/10 06:48 PM
Does anybody know about how much free clearance space there is on the drivetrain for a 5spd 90s xt-cab pickup?
I'd like to tuck it up out of the way as much as possible, but would prefer to minimize the amount of body lifting I do. E.g. can you get 1.5-2"?
Where are the typical interference areas? I know the back of the motor/bell housing doesn't have much space at the tunnel, and I assume the shifters must be pretty close. The truck bed will be removed.
related - is there any real harm in lifting the back but not the motor end? I could see this adding some tress to the motor mounts by twisting them a bit, but the 2-3 degree angle from only 2" over the 3.5'(?) span seems pretty minimal.
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
Re: Clearance available for drivetrain lift
[Re: 4Crawler]
#1016265
12/27/10 08:57 PM
Thanks Roger. I'd read your article on doing the drivetrain lift, just a little unlear on whether the space may be any different on the 90s trucks. Comparing the 93 Ext-cab to my 88 4Runner, it looks liek all te hmain players are in about teh same place, just not sure if the floor pans are a much different height at the tunnel etc.
I figured I'd have to pay attention to the CSB but didn't realize te hangle would be a problem, good note on that. I wonder, though, if that thing could be shimmed to drop a little wit ha built-in angle at angle like we do axle perches to accomodate the angle. I'll probably add a leaf spring lift, or at least longer shackles, so that issue would come up anyway. Changing to a single long shaft would be an option as well, but I feel like that only increases the chances of banging on something, that 65" long sucker would be really exposed.
[Re: RatLabGuy]
#1016266
12/27/10 10:59 PM
good timing....i am thinking about this as well. i want to switch to a 4.7 gear drive case and get a budbuilt with like 2" of lift, since i have a 1" bl. that will make a HUGH difference under the truck. my other concern is the length of a v6 adapter and gear drive case vs the chain drive case...but that is for another thread....
i have read that many people just loosen the motor mounts and raise the transfer case and then tighten up the motor mounts again and all is good. i have an electric fan so this shouldnt be a problem. it might be with a stock fan. let us know how it works out!
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
[Re: Rodgertheshrubber]
#1016267
12/27/10 11:17 PM
i have an electric fan so this shouldnt be a problem. it might be with a stock fan. let us know how it works out! Hm, another good point - theoretically it is doing 2 bad things, tipping the top of teh fan blades into the radiator (yeah, not a lot of clearance there) and also changing the angle of air movement so it is no long straight on. But again, 2 deg should be minimal... However I think Roger is right, it's really just a matter of unbolting the rear mounts and lifting it up to see.
[Re: RatLabGuy]
#1016268
12/28/10 12:32 AM
I figured I'd have to pay attention to the CSB but didn't realize te hangle would be a problem, good note on that. I wonder, though, if that thing could be shimmed to drop a little wit ha built-in angle at angle like we do axle perches to accomodate the angle. I'll probably add a leaf spring lift, or at least longer shackles, so that issue would come up anyway. Problem with CSB, or rather that little upper shaft is that it typically has one u-joint and w/ 1 u-joint, you must run that shaft with 0 degree angle on that joint for no vibration. IOW, it must be dead in line with the t-case output flange or in whatever alignment it is now. If t-case is raise, CSB would need to be raised to match in most cases.
[Re: 4Crawler]
#1016269
01/04/11 04:31 PM
Does anybody know if there is a chart/source somewhere that lists the length of the various stock Toy driveshafts?
I'm now seriously considering shortening the wheelbase on this truck, by moving the rear springs/axle forward maybe 12-19" or so (after ditching the bed of course). If I do, obviously the CSB will go away; I'm wondering if I might get lucky and be able to either re-use just the main shaft (w/ CV) from this truck (unlikely), or at least get a junkyard one from a different model Toy (e.g. A/T 4runner?) that will bolt up - much cheaper than having one fabbed.
