Re: Serpentine belt squeal!
[Re: dougl3nc]
#1016425
12/30/10 02:43 PM
With a squeal like you have there will generally be rubber around the pulley that is slipping. Which belt is making noise?
[Re: OldColt]
#1016426
12/30/10 04:40 PM
Which belt is making noise? The only one! Serpentine belt on the 3.5. I guess my tensioner really is bad...there goes another $150. The belt I took off looked like new, just was a little shiny on the ribbed side. No cracking or shredding at all. No rubber residue on any pulley.
1989 Raider SWB Auto 3.0L...It's ALIVE! Currently on a shakedown cruise...
[Re: dougl3nc]
#1016427
12/31/10 04:32 AM
Take a hand full of fine dirt and dust the belt while it is running....Try it I dare you...
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
[Re: dougl3nc]
#1016428
01/10/11 03:24 AM
on the 3l, I've found that not all alternators are the same, and they don't always tighten down the same, either.
What happened to mine was that the alternator sat just a touch forward- not much, but just enough to push the belt into the edge of one of the idlers. I could at one point actually pry on the alternator while it was running to make the squeak go away. I put a thin washer in one side of the mount to shift the alt just a touch- problem solved.
So look at the ledges on the non- ribbed pulleys- you might find one is shiny where the belt's been touching it.
That might help find the culprit...
hth
t
'89 V6 4dr- '4- Doris'
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6055 MB (Peak: 0.6777 MB) Data Comp: Off Server Time: 2026-06-07 07:22:08 UTCValid HTML 5 and Valid CSS
