Re: Turning radius is balls [Re: LeeForget] #1016807 01/03/11 05:04 AM
Kevin C Offline
Are you sure that your 35"s are allowing you to hit the steering limiters when you turn?
Re: Turning radius is balls [Re: Kevin C] #1016808 01/03/11 05:43 AM
LandRaider Offline
36's and the Lugs on my swampers kiss the leaf springs, but yes... they are hitting the locks on each side.
Re: Turning radius is balls [Re: LandRaider] #1016809 01/03/11 06:11 AM
L
LeeForget Offline OP
i think he was talking to me.
i dont have my 35's on yet, still have my 31's on there. i checked to see if their rubbing the frame/body at all and their not even close.
~88 Raider 2.6L 5 speed
~35"x14.5"r15
~SOA(Spring Over Axle)
~TT(Torsion Twist)
~SBL(Sloped body lift)
Re: Turning radius is balls [Re: LeeForget] #1016810 01/03/11 01:09 PM
I turned the stops way in on my 87. It turns a lot tighter but yo need to use a very light touch with your hands at the limit. The CVs at ride height have more travel available allowing a tighter turn but as soon as one wheel drops they will bind up. You need to feel for this when driving. If you just turn to the limit and hold it there with the stops adjusted back and drive over terrain the next clunk you hear will not make you happy.
Re: Turning radius is balls [Re: OldColt] #1016811 01/10/11 03:15 AM
TobyB Offline
funny, I was just thinking that....
yeah, honestly, I'm always surprised when I get into
a different car, crank the wheel over- and hey, wow,
this thing will turn sharp!
The LWB is even worse- well, it's longer!
heh
e
'89 V6 4dr- '4- Doris'
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6121 MB (Peak: 0.6931 MB) Data Comp: Off Server Time: 2026-06-07 07:25:41 UTC
