Page 1 of 4 1 2 3 4
Drive shaft problems?? #1017020 01/04/11 05:38 PM
RockU Offline OP
Ever since I've owned my Monty, the front drive shaft (between front axle and transfer case) rubs metal on metal against case, destroying oil seals religiously. I plan to shorten it by 1" by a local machinist so it's balanced.
Has anybody every had this issue? Any suggestions? <img src="/forums/images/graemlins/frown.gif" alt="" />
RockU - Federal Way, WA - 1989 Montero, New-2.6L, New-5spd, New Clutch, header, 10x15 wheels, 32x11.5x15 Mud Claw (Cardovan), 4" lift, Superwinch Hubs, Front LSD, Synch 38/38 Weber Carb, K&N filter, (Let's hit the trail!) Home Email: jondanderson2002@yahoo.com
Re: Drive shaft problems?? [Re: RockU] #1017021 01/04/11 06:22 PM
This is not a common problem. Any chance it had the wrong shaft installed, as in too long? Or and damage history that would have moved the diff back?
Re: Drive shaft problems?? [Re: OldColt] #1017022 01/04/11 10:52 PM
dadrab Offline
I've never heard of such...
Any possibility of looking under a known "good" unit to see how yours stacks up in comparison? Sounds almost like the frame could be out of square.
with awesome audio.
Re: Drive shaft problems?? [Re: dadrab] #1017023 01/05/11 02:17 AM
I have not put the two pieces side by side for the 4-cyl, but I think auto and stick driveshafts have different lengths. Measure yours and let me know the length. I have some stick shafts that could be sent to you for the shipping price.
Russell
Re: Drive shaft problems?? [Re: rxinhed] #1017024 01/05/11 01:47 PM
plh Offline
I'm pretty sure the Auto and Stick drive shafts for the 4 Cyl are different lengths. Plus the 6 cyl vs. the 4 cyl are different too. I also have a spare shaft from a 4 cyl 5 speed. If Rx's are not the correct length, send me a PM. Same deal - u pay shipping and its yours.
Maybe somebody swapped in a V6 front differential and did not swap the drive shaft. The 4 cyl manual shaft is 1" longer than the V6 manual, so after the differential swap the shorter drive shaft is required.
Here is my LSD / differential swap post explaining it.
LSD Install
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Drive shaft problems?? [Re: rxinhed] #1017025 01/05/11 10:55 PM
RockU Offline OP
I'll measure it and re-post tonight!
Re: Drive shaft problems?? [Re: plh] #1017026 01/05/11 10:58 PM
RockU Offline OP
After purchasing the Monty, the only thing I've done to the front axle is swap out the guts with an V6 LSD axle and re-installed it...
And I'll measure my mess and re-post tonight... Thanks a lot you guys!
Re: Drive shaft problems?? [Re: RockU] #1017027 01/06/11 12:32 AM
plh Offline
I think you will need a V6 manual transmission drive shaft. The 1" extra length of the 4 cylinder shaft would explain why your seals are getting hammered.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Drive shaft problems?? [Re: plh] #1017028 01/06/11 01:27 AM
RockU Offline OP
Phl it's 33.1/4 inches.
Re: Drive shaft problems?? [Re: rxinhed] #1017029 01/06/11 01:29 AM
RockU Offline OP
Russ it's 33.1/4 inches.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6491 MB (Peak: 0.7692 MB) Data Comp: Off Server Time: 2026-11-03 04:53:59 UTC
