WTB: MD126339 ECU 1989 Monty V6 LWB #1017295 01/07/11 01:29 AM
E
evotechnik Offline OP
I have the right ECU since my car is a CA emissions car.
I was driving down the freeway and the car suddenly died. I have changed the wires, plugs, Filter, Flushed out the coolant checked for leaks in the intake and exhaust. I'm thinking it could be a bad fuel pump. The car cranks over I didnt see any wet plugs so that could be the issue. I had also just replaced the ECU with another one that I had found. Hopefully it isnt another bad ECU. Any Ideas?
Re: WTB: MD126339 ECU 1989 Monty V6 LWB [Re: evotechnik] #1017296 01/08/11 04:04 AM
hazy_daze Offline
Wrong forum to try to diagnose your issue. Move over to Mitsu tech for alot more exposure to some very knowledgeable readers.
A bad ECU can inhibit the pump from coming on. Have you opened its case to take a whiff? To check your pumps' physical operation, apply 12v to the test plug in the passenger footwell.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5881 MB (Peak: 0.6365 MB) Data Comp: Off Server Time: 2026-06-22 11:20:20 UTC
