need help clutch #1017649 11/28/01 12:55 AM
Mike Bridges Offline OP
I need help,pointers,ideas,anything. I have a 67 bronco halfcab that I just bought,the clutch was out(slipping) when I bought it. I put in a new clutch p.plate and t.bearing along with a new roller pilot bearing all new from ford.(flywheel resurfaced) The bronco chatters,shakes,vibrates or what ever you want to call it so bad that its not driveable. It only does it on pulling out from a dead stop going foward, no problems backing up.<BR> It has a 289,all new bushings in the springs and trans. mount I'm out of ideas,any help or ideas on what to do or look for. thanks for any info. mike bridges
Re: need help clutch #1017650 11/28/01 04:31 AM
If the chattering started after replacing the clutch, check the obvious first.<BR>Sounds like it could be a mis-adjusted clutch<BR>(not fully disengaged when foot off pedal).<P>Lower ratio gears(reverse or granny low) reduce strain of setting into motion from a dead stop, and might explain no shuttering effect while in reverse.<BR>Adjust the clutch pedal first, to allow proper pedal "freeplay"
Re: need help clutch #1017651 11/28/01 11:55 PM
<BLOCKQUOTE><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><HR>Originally posted by McLeod:<BR><STRONG>If the chattering started after replacing the clutch, check the obvious first.<BR>Sounds like it could be a mis-adjusted clutch<BR>(not fully disengaged when foot off pedal).<P>Lower ratio gears(reverse or granny low) reduce strain of setting into motion from a dead stop, and might explain no shuttering effect while in reverse.<BR>Adjust the clutch pedal first, to allow proper pedal "freeplay"</STRONG><HR></BLOCKQUOTE><P> The bronco was not driveable when I bought it,the clutch slipped so bad it would not even move. I pulled the engine and replaced the clutch,with all the normal parts(resurface flywheel,pilot bearing,new clutch fork) <BR> It drives fine after getting pulled out,no noises from anywhere shifts smooth. Stop and pull out chatters like crazy,even in fourwheel drive but it backs up without a problem. I'm lost talked to the guy I bought it from and he said it chattered a little before the clutch went out,but who knows.<BR> thanks for your time and ideas.<BR> mike bridges
Re: need help clutch #1017652 11/29/01 05:14 AM
I would work my way towards rear.<BR>Driveline angle, if lifted vehicle could be severe enough to bind u joints.<BR>Check for sloppy rear axle. I had a front axle "TracLok" that chattered just before it went out. Spider gears in rear dif?,
Re: need help clutch #1017653 11/30/01 06:16 AM
Broncrick Offline
Emeritus Ford Moderator
Sounds wierd, the new parts and flywheel re-surface should have done it, cured mine. Ok how are your mounts? tight? spring shape? and what tires/gears are you running?<P>Rick-
Rick Esterly
69 EB Locked and Loaded
99 Taco Xcab
www.4x4Wire.com
www.RocknRoll4x4.com
Re: need help clutch #1017654 11/30/01 05:54 AM
What axle ratio are you running and what tire size?<BR>If you have 3.50 ratio with 33" tires, you are extremely high geared.<BR>Some clutch chatter should be expected when running a high drive ratio.
Re: need help clutch #1017655 11/30/01 10:59 PM
All the mounts are new (engine and trans.)I put the engine mounts on when I replaced the clutch. <BR> It's stock height has the 4.10 or 4.11 (how ever you want to add it) gears and worn 30inch tires. I work as a mechanic(not so sure anymore) at a dealer ship. No one here knows either but they sure think it's funny. I usually do all the trouble shooting,but I'm still lost on this one. <BR> It has all new poly-bushing in it(springs and the body mounts and so on). It runs and drives great no shakes, rattles or squeaks. <BR> The thing just chatters from a dead stop or almost stopped, if moving at a couple miles an hour it's fine. <BR> Do you think I've just got a bad new FORD clutch? If so it's the first for me. I install about 40 or so a year at the shop. I can do it again but don't think it will prove anything,was hoping it was simple. I guess murphy came to visit. thanks <BR> mike bridges [img]images/icons/confused.gif" border="0[/img]
Re: need help clutch #1017656 12/01/01 02:05 AM
Sounds like you know what your doing.<BR>I wouldn't put too much faith in factory parts anymore. Ford has had alot of problems with their diesel flywheels coming apart recently.<P>I know it's alot of work, but if it bothered me (and it probably would), I'd put in an aftermarket pressure plate. One that has a very heavy pedal.<P>I'm interested in what you find out. Please post your discovery here.<P>Good luck! [img]images/icons/smile.gif" border="0[/img]
Re: need help clutch #1017657 12/02/01 12:09 AM
I'll let you all know here in a few weeks,(we have a 2week shut down at christmas)if the weather holds.I plan on doing it again and using a centerforce clutch,I'm going to use the diaphragm style instead of the lond style and see if it helps. Thanks for the ideas. mike bridges
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6193 MB (Peak: 0.7216 MB) Data Comp: Off Server Time: 2026-06-17 03:33:01 UTC
