Getting an Engine ECU rebuilt #1018395 01/17/11 01:08 AM
Houston Offline OP
Does anyone have a current place to send a Gen 2 ECU [3.0 12 valve] for rebuilding if it's possible. I replaced my dead ECU for a working junkyard unit since I lost ign. coil control a few weeks ago. I'd like to get my old ECU fixed as a back-up. Learned how to check ECU and Distributor harness, and found the hidden "ground #8" for the ECU next to the blower motor housing where it's totally NOT easy to get at if needed. Also learned that Mitsu added different engine ecu grounds after that, 2 of them, and they're in way easier places to clean, check/verify[Sometimes it sucks being a first year production vehicle! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />]
Also, is anyone in need of a post on replacing the heaterbox or heater core in their Gen 2 Monty? I recently replaced the heaterbox with a new one, since my original core finally started leaking bad a few weeks before Christmas. Could NOT find a heatercore for a Gen 2, only Gen 1s. The heaterbox was the last one listed in dealer part distr. network in the USA. The new core in the brand new heaterbox is aluminum and one piece, not brass with several hose clamped sections like the old factory part. And aside from not being clogged like the old part, it heats up much faster than the brass part ever did. I learned some interesting stuff about removing the dash during R&R of the heaterbox, and nothing broke in the way of aging plastic, which is always a bonus. <img src="/forums/images/graemlins/drunk.gif" alt="" />
Anyway, let me know, as I took a few pictures of the process, and still have the old 'box as a reference part if needed for this forum.
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: Getting an Engine ECU rebuilt [Re: Houston] #1018396 01/17/11 03:03 AM
Pete_D Offline
When I used to be in the business there was a place in Texas that did that. Dallas??? Not sure. Maybe you could ask at some repair shops in your area or check the web.
Good luck
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: Getting an Engine ECU rebuilt [Re: Pete_D] #1018397 01/17/11 03:18 AM
KrzyDav Offline
It's in Houston , Houston. Google ECU. I can't remimber the name of the place but theyv'e been around awhile. It's like 300 bucks .
If your circuit boards hasn't been destroyed by acid you might find somebody who can just replace the capacitors. That's usually what goes bad and leaks on these.
???Maybe somebody has done that on here and can tell us what kind/size/part number of those capacitors???
dave h.
Re: Getting an Engine ECU rebuilt [Re: KrzyDav] #1018398 01/17/11 08:04 AM
3
300D50 Offline
Depending on what died, it might be a simple clean and re-cap.
I'd say pop the cover off and look for corrosion, bulged caps, or exploded IC's.
If you want, I could take a look at it , but since I don't have a V6 all I could do is a general rework and replace the caps and coil drivers if they're dead.
I work for peanuts, so it wouldn't be that much.
Lmk if you're interested.
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: Getting an Engine ECU rebuilt [Re: Houston] #1018399 01/17/11 09:14 AM
A
airbats801 Offline
Any idea whats goes out in them? is it the caps like the 1g dsm computers that leak?
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: Getting an Engine ECU rebuilt [Re: 300D50] #1018400 01/17/11 12:15 PM
The foam ones or the type that needs the shell removed?
Re: Getting an Engine ECU rebuilt [Re: 300D50] #1018401 01/17/11 04:38 PM
Houston Offline OP
I pulled the case apart before I ever ordered a junkyard replacement. Nothing burned, leaking or otherwise looks wrong with the circuit board and its components. I lost the driver/final stage control for the ignition coil, but no melted parts on the board, so I don't know if the ECU is fixable or not. I'll try looking up the Houston rebuilder, thanks
Re: Getting an Engine ECU rebuilt [Re: Houston] #1018402 01/17/11 05:27 PM
If you trace in from the connector you can find which device is the ignition driver. Get the number off it and buy a replacement from Mouser, Digikey or such. The devices that are not available in country are the low, long black output transistor that are grouped together. These control fuel pump, AC and such. They get scrounged from other ECUs.
It is possible that the failure might not be in the output but in the chip that controls the output. When I find that I consider the board dead.
Re: Getting an Engine ECU rebuilt [Re: Houston] #1018403 01/17/11 07:47 PM
Grasscat Offline
Talk to Nick, 239-849-0981 @ AV-Pro Company in Fort Myers Beach, Fl.and explain you problem. I sent my ECM to him $150 and one day service.
Michael j
TreadLightly! Trainer
Re: Getting an Engine ECU rebuilt [Re: OldColt] #1018404 01/17/11 11:38 PM
3
300D50 Offline
The type that pay down student loans! <img src="/forums/images/graemlins/lol.gif" alt="" />
I've got a source for the dual drivers you speak of, new.
One of the distributors I deal with specializes in obsolete parts.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6485 MB (Peak: 0.7695 MB) Data Comp: Off Server Time: 2026-06-17 06:49:35 UTC
