Page 1 of 6 1 2 3 4 5 6
exhaust replacement #1018778 01/20/11 06:03 PM
londart Offline OP
ok so my muffler has a huge hole in it and will be replacing soon...if i'm gonna replace it i might as well upgrade the exhaust...gonna go with a thrush welded turbo muffler i think,but my question is what size is best for performance,too big or too small are both bad and definately dont want it as loud as it is now lol....the cat (95 so there is only the 1) is already gutted,i checked when i thought it was plugged,so figure upgrade from catback...was thinking 2-1/2" but didnt know if i should just go 2-1/4"...figure replace pipe to muffler,muffler, than tail pipe exit out the back instead of a turndown @ end of muffler like it was when i bought it..what do you guys think?
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: exhaust replacement [Re: londart] #1018779 01/20/11 06:54 PM
logansportage Offline
I went with a 2.5" after cat back exhaust with a Spin Tech muffler. I love it. It starts out with a deeper sound than stock, but flattens off at 3500 RPM. With the Sportage typically running at well above 3500 RPM when driving the sound is just deeper than stock, but not loud. I had a 4" tip on it that made it louder becasue the shop didn't have the 3" tip I wanted when I had it installed. It recently rusted off, so now I'm going to have them redo the tail pipe with just a 3" tip instead. I'll probably have them cut out the cat when I do it and have it replaced with a High Flow cat.
Re: exhaust replacement [Re: logansportage] #1018780 01/20/11 07:39 PM
londart Offline OP
so is the spin tech a turbo muffler as well?
Lonnie
Re: exhaust replacement [Re: londart] #1018781 01/20/11 08:39 PM
Here is a link for them.
http://www.spintechmufflers.com/
If by spinning the air it makes it a Turbo muffler, then yes. It does a lot more though. Check them out. I've been really happy with them. More than the Magnaflow or Flow Master stuff I've used in the past.
Re: exhaust replacement [Re: logansportage] #1018782 01/20/11 10:22 PM
promodmerc Offline
The Spintech is not a turbo muffler. I have a Thrush Turbo on mine and like it. The welded Thrush muffler is going to be louder because it is a Flowmaster knock off.
The longer and wider the muffler the quieter it will be.
Re: exhaust replacement [Re: promodmerc] #1018783 01/20/11 10:36 PM
londart Offline OP
ya we sell both thrushes @ my work..i just know the welded are built better,wasnt sure about the sound,..wouldnt mind if it was a lil loud if it sounded good but right now i sound like i'm racin @ the circle track...if my wife is outside she can hear me get on the freeway...thats a good 5or 6 blocks away....i didnt belive her til i was on the phone with her and she said oh ur gettin on the freeway and was right @ full throttle on the on ramp lol
Lonnie
Re: exhaust replacement [Re: londart] #1018784 01/20/11 11:17 PM
promodmerc Offline
I have a '97 Vougar with a 4.6 V8. I had the Thrush welded mufflers on it. I than last fall had the third cat removed and had true duals put on. The Thrush welded mufflers sounded like crap after the cat delete so I put Magnaflow's on.
I could be wrong but I have a feeling with the Thrush welded muffler your Sportage will sound like every teenagers Honda.
Re: exhaust replacement [Re: promodmerc] #1018785 01/21/11 12:21 AM
londart Offline OP
so the thrush turbo doesn't sound like a honda on your sportage though?
Lonnie
Re: exhaust replacement [Re: londart] #1018786 01/21/11 05:23 AM
promodmerc Offline
No it doesn't. Around 25-30 it has a resonance to it but that is all. I don't notice it at hi-way speeds and I have a two door. My exhaust is all 2" as well.
Re: exhaust replacement [Re: promodmerc] #1018787 01/21/11 05:38 AM
Everet Offline
Try the Thrush single inlet and dual outlet. Sounds great and looks pretty cool too.
Just remember, less backpressure changes your torque curve and you loose low end torque.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6390 MB (Peak: 0.7630 MB) Data Comp: Off Server Time: 2026-11-03 13:24:28 UTC
