Page 3 of 3 1 2 3
Re: Considering SAS [Re: Chad Hunter] #1018936 04/11/11 07:23 PM
jeffs_62 Offline OP
Chad, your post intrigued me. I would like to hear more on dual cases. I haven't had my Trooper that long, although the end result is a capable overlander, what I know about dual cases only makes it more capable, without any ill affects on on-road handling.
Re: Considering SAS [Re: jeffs_62] #1018937 04/13/11 06:46 PM
Chad Hunter Offline
There is no easy way to do dual cases.
Rob G, Troy, and myself figured out a way to use an isuzu auto case behind the stock case. Its a roll your own deal and much fabrication is involved. We all went with slightly different methods to achieve the same results. Basically you cut off the front output portion of the stock case and mount up the auto case behind it. Much more to it than that, but thats it in a nutshell.
Corbin found that with the bellhousing from a '98+ trooper 5speed he could use a toyota turbo tranny and then used toyota dual cases. Randii, back in the early days had an ultra rare one off bellhousing that mated the 2.6 to a toyota tranny with dual toy cases. Dan pitched the isuzu tranny and went with some other tranny/tcase combo. Dallas swapped a 4.3/700r4/dana 300 combo.
So, there are many ways to get there, but none are very easy.
I always really liked Corbins set-up, but it would be expensive to replicate.
1987 trooper LS.'94 3.2, SAS,35's , lots of dents and rust. Now, improved, with more dents.
1995 trooper LS. Wife won't let me improve this one.
1996 trooper. I'll need something to modify when the '87 finally rusts away.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.008s) Memory: 0.5959 MB (Peak: 0.6606 MB) Data Comp: Off Server Time: 2026-10-24 13:10:14 UTC
