Auto Locking Hubs #1018956 01/22/11 03:38 AM
8
87Raider Offline OP
Hello, I replaced the rotors today and when i put the hubs back on, the right hub seems to put drag on the bearings. if i loosen it up a hair it spins freely. I also noticed a coiled piece on metal inside both the hubs, not sure whats broke inside, They still work, I took it out in the dirt and they lock and unlock. Anyone have a clue whats causing the drag or what the piece of metal is? Thanks Mike
Re: Auto Locking Hubs [Re: 87Raider] #1018957 01/22/11 05:59 AM
When you had the rotor and hub assemblies off, you put the little spacer washer back on the CV shaft, under the C clip? Are you sure the auto hubs are fully retracting the lock mechanism? They need to be lubed with a light grease, like white lithium. Not really much else...
Re: Auto Locking Hubs [Re: rxinhed] #1018958 01/22/11 06:20 PM
8
87Raider Offline OP
Not sure what spacer your talking about, everything that came off went back on. I had new rotors put on 2yrs ago (china) and the guy said he packed the bearing for me also, maybe he left something out? but the left side has no drag.
Re: Auto Locking Hubs [Re: 87Raider] #1018959 01/23/11 12:59 AM
There is a small spacer between the hub and CV axle on the inside of the spindle. On the outside portion of the wheel bearings, you have the adjuster, lock washer and hardware, and the little retaining clip on the CV shaft. Is the wheel loose? If nothing new was added or old lost, shouldn't have any drag issues. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Auto Locking Hubs [Re: rxinhed] #1018960 01/23/11 08:04 PM
8
87Raider Offline OP
Well it was the way i put it back together,
i didnt realize there was a key on the hub also, I reinstalled it correctly and everything is good to go.
Re: Auto Locking Hubs [Re: 87Raider] #1018961 01/23/11 08:37 PM
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6093 MB (Peak: 0.6796 MB) Data Comp: Off Server Time: 2026-06-13 10:54:45 UTC
