welded diff #1019034 01/23/11 02:10 PM
L
LeeForget Offline OP
just making sure i got this right before i go ahead and do it.. follow this post
http://www.4x4wire.com/forums/showflat.p...p;vc=1&nt=2
up to here :
then weld these gears like this (this is a chevy gear)
reassemble, fill with fluid, now you've got locker?
::EDIT::
ive also seen where they just take all these gears and weld them to the housing :
which method would be correct? or stronger? im thinking welding them all to the housing would be pretty much the same thing, and be a lot stronger.
~88 Raider 2.6L 5 speed
~35"x14.5"r15
~SOA(Spring Over Axle)
~TT(Torsion Twist)
~SBL(Sloped body lift)
Re: welded diff [Re: LeeForget] #1019035 01/24/11 04:50 AM
LandRaider Offline
If you do it like that, it'll prob blow up.
You need to weld the spider gears to themselves while they are inside the differential.
Search Lincoln Locker, and you will find many posts on this. I've written out explicit instruction to it before.
Re: welded diff [Re: LandRaider] #1019036 01/24/11 05:18 AM
Kevin C Offline
If you dont have a welder, cant you just fill the teeth in with JB weld? It cures up pretty darn hard.
Re: welded diff [Re: LandRaider] #1019037 01/24/11 05:22 AM
SRTNate Offline
With the pin in, I tacked the gears in front. Then I pulled the pin out and rotated the assembly 90 degrees so I could weld the back side of the gears. This pic just shows the tacks before I did the full weld...I was able to weld the full length between the tack welds:
I then rotated it back the way it's supposed to be, but the pin back in, and then finished welding from the front.
Sorry, I took this pic a few months ago and didn't realize that it was out of focus. Hopefully it's good enough to get the idea.
1989 Mitsubishi Montero SWB 0.0L (3.5L soon?) Auto, Front LSD, Rear SR Locker, Aisin hubs, Safari Snorkel, ARB Front Bumper, Warn M8000, Bushwacker Flares
1984 Mitsubishi Montero
2005 Dodge SRT-4
1970 Plymouth 'Cuda (in pieces)
...and a few others less interesting.
Re: welded diff [Re: Kevin C] #1019038 01/24/11 05:28 AM
justice Offline
This is the way I usually do it. It can affect horsepower though...
Re: welded diff [Re: justice] #1019039 01/24/11 06:04 AM
Kevin C Offline
Must be tricky to get it into the case like that.
Re: welded diff [Re: Kevin C] #1019040 01/24/11 07:14 AM
A
airbats801 Offline
lol, I'd imagine it's a real bear to setup the gear mesh pattern also smile
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: welded diff [Re: justice] #1019041 01/24/11 01:13 PM
That should quiet down those noisy gears.
Re: welded diff [Re: OldColt] #1019042 01/24/11 08:00 PM
Weld the gears together only, welding to the housing will crack because of the type of casting it is. I plate over the pin and weld the gears together and to the plate.
Re: welded diff [Re: LandRaider] #1019043 01/25/11 02:50 AM
L
Thanks guys. Ill get back to ya after ive welded her up.
~35"x14.5"r15
~TT(Torsion Twist)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6375 MB (Peak: 0.7467 MB) Data Comp: Off Server Time: 2026-06-07 07:03:57 UTC
