Recommend oil for 2.6 #1019044 01/23/11 06:15 PM
bar2hunter Offline OP
I have a 88 Raider 2.6 auto with 214,000 miles. It appears that it's an oil burner <img src="/forums/images/graemlins/frown.gif" alt="" />, as well as a gas guzzler <img src="/forums/images/graemlins/frown.gif" alt="" />.
What engine oil do you all suggest?
Re: Recommend oil for 2.6 [Re: bar2hunter] #1019045 01/23/11 08:51 PM
10W-40. Don't get all fancy. Don't use Fram oil filters.
Re: Recommend oil for 2.6 [Re: JohnnyBfromPeoria] #1019046 01/23/11 09:30 PM
John, what do you mean by "fancy"? Please explain.
Thanks, Tony
Re: Recommend oil for 2.6 [Re: bar2hunter] #1019047 01/23/11 10:07 PM
Kevin C Offline
Thanks, Tony
Fancy = $8+ a qt synthetic
Not fancy = it had some marking that implied there is motor oil in the container.
Normal = it says Castrol 10W-40 and does not require a second mortgage to do an oil change.
Re: Recommend oil for 2.6 [Re: Kevin C] #1019048 01/23/11 10:12 PM
Exactly.
Re: Recommend oil for 2.6 [Re: JohnnyBfromPeoria] #1019049 01/23/11 11:25 PM
JAVYPRO Offline
Me too, Castrol 10W40. $10 - $12 for the 5qt jug at Walmart + 1 more qt <img src="/forums/images/graemlins/kewl.gif" alt="" />. FRAM <img src="/forums/images/graemlins/shame.gif" alt="" />
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Recommend oil for 2.6 [Re: JAVYPRO] #1019050 01/24/11 01:29 AM
A
airbats801 Offline
I've always ran 10w30, just cheap crap if im not beating on it, When I use to drift n drag my starion, I ran mobil 1 10w30 synthetic, and used a extra quart, use ti spin the engine up wo 8000 to 8100 and nver blew it up. IMO if you are gonna flog the hell out of it then use synthetic and add a little more, otherwise just use some cheap crappy oil. I woldnt use castrol, but for me its just personal as I use o work for them.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6219 MB (Peak: 0.6964 MB) Data Comp: Off Server Time: 2026-11-16 01:26:34 UTC
