Inside front tire wear? wanders all over highway #1019199 01/26/11 01:49 AM
HuntingRig Offline OP
I had a lot of tread left on my mud terrains, but about two months ago I jumped in the 87 4runner & it seemed like I was all over the highway. Prior to this I noticed my steering stabilizer was leaking slightly.
I hadn't drove it in a few months, so I figured it was me. I then let my buddy drive it for about a month & it came back with both inside front tires worn down to nothing. It's been sitting for about a month & I am pricing two new muds & an alignment. Do you guys think its just an alignment issue?
I replacement front shocks, ball joints & cv shafts last year.
Re: Inside front tire wear? wanders all over highway [Re: HuntingRig] #1019200 01/26/11 02:52 AM
4Crawler Offline
Might be too much toe out, easy to check with a tape measure between the front and rear of the front tires.
Re: Inside front tire wear? wanders all over highway [Re: 4Crawler] #1019201 01/26/11 07:06 AM
OOP'S Offline
Could be your upper and lower A arm bushings are worn out. Also check your idler arm and TRE's
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Inside front tire wear? wanders all over highway [Re: HuntingRig] #1019202 01/26/11 09:26 AM
kewlynx Offline
Just did a bushing R&R Read away
When these ol' gals start getting this old, they need some good old fashion maintenance.
**ubi apis- ibi salus**
Re: Inside front tire wear? wanders all over highway [Re: kewlynx] #1019203 01/26/11 03:22 PM
Outside measurement on the front of the tire is 71 3/4".
outside measurement on the back of the tire is 70 1/4".
I did some reading & it looks like anything over 1/8" on toe out will cause the tires to scrub. Is this true?
I know I need to replace the bushings soon, but it will have to wait for another day.
Re: Inside front tire wear? wanders all over highway [Re: HuntingRig] #1019204 01/26/11 05:03 PM
4Crawler Offline
Re: Inside front tire wear? wanders all over highway [Re: HuntingRig] #1019205 01/27/11 01:01 AM
Dandeman Offline
Toyota Moderator
Ouch! <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> It has gone beyond toe'd out to outright spread eagle.
Is there excessive slop in the joints/bushings? Otherwise would be looking for something bent to be that far out...
Re: Inside front tire wear? wanders all over highway [Re: Dandeman] #1019206 01/27/11 01:06 AM
Okay just got some new muds on the front.
Idler arm is shot! I just picked a new one up & I am going to put it on & then work on toe-out. I think the bushings on the arms need to be replaced also... that's going to have to wait for another day & I need to repack the wheel bearings! <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Inside front tire wear? wanders all over highway [Re: HuntingRig] #1019207 01/27/11 01:25 AM
What are the Negative Camber tolerances?
I have also noticed mine front tires have negative camber for a while & not sure what the tolerances are...
it's 50 7/8 toe in & 50 3/8 toe out inside tire. My daughter helped me measure in the dark this morning & she didn't hold the tape on the outside very well! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Inside front tire wear? wanders all over highway [Re: HuntingRig] #1019208 01/27/11 03:12 AM
OOP'S Offline
All of that info is in the FSM sticky at the top of this page. It is for a 93 but the IFS specs were the same from 86-95.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6443 MB (Peak: 0.7687 MB) Data Comp: Off Server Time: 2026-05-26 04:56:37 UTC
