Page 1 of 7 1 2 3 4 5 6 7
Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door #1019297 01/27/11 05:14 AM
jacumja Offline OP
First thanks for taking the time to read this. I really do appreciate the input and your advice is important to me. I'm a big fan of import 4x4's I've mainly owned Sammy's and Toyotas. I was born in 79 so that might be why the only 2 door small import 4x4 I ever saw was the Sammy, real working 4x4's. Sorry if your into Bronco 2's or Chevy Blazers they just underperform in the woods.
I recently had my locked and sas 99 4runner totaled courtesy of a drunk. A few days ago while perusing my local Clist I came across a Dodge Raider. Needless to say I stayed up until 4am that night investigating what it was. I loved the way it looked. I also checked out the Montero 2 door and the ultra rare 2 door Trooper. I've seen all types and I wanted to know from real owners what I'm in for. I hear bad stuff but all of it comes from non owners. The Raiders I feel like have gotten a bad rap much like Land Rover Discoveries. Most people that own disco's don't ever take them on dirt let alone know how to turn a wrench. I own approximately 400 acres of coastal marshland and timber so I need a light 4x4. I am there on the weekends but am in the city during the week. I don't drive for work but I do drive to and from work. I also do the occasional highway trip and pulling a boat/jet ski. With that in mind here are my questions.
1. It seems like the 4 cylinder even with a 5 speed is very sluggish. This would make sense considering its a 4 cylinder. Is this true or false?
2. I've read you want the 6 cylinders because the 4's are terrible once they have problems. Most people swap them for a different motor all together?
3. I'd probably prefer an automatic because I really don't need the control over my gears that often and stop and go traffic isn't fun with a 5 speed all the time. Is the auto tranny reliable or do I want the 5 speed?
4. Is there a certain year I should be weary of , there were only 3 so this might be a stupid question?
5. Any bad service issues that I should make sure have been taken care of before buying one. Excluding the obvious like timing belts etc?
6. I'm 6'4 and just sat in my first Raider today. It definetly feels wider and has more headroom than a Samurai and the chair seems to sit higher. I was uncomfortable but that was because of the "school bus steering wheel" I've only seen bigger on an Internation 800 and older. Are the front seats modifiable? I def noticed more room behind the rear seat for gear as well.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019298 01/27/11 05:51 AM
FrankR Offline
Welcome!
I've only driven one 4 cylinder and found it to be sluggish, but the engine may have been worn out. I also found the 6 cylinder to be sluggish with large tires on grades, but I fixed that. <img src="/forums/images/graemlins/wink.gif" alt="" />
Most any modern engine is a major cost when you have a problem. The 4 cylinder is probably no worse than the 6 cylinder in cost. Both are fairly easy to work on for an average mechanic. Most owners do not swap engines, but there is a nifty turbo engine swap for the 4 cylinder that makes it into a beast. There are no easy drop-ins for replacing the 6 cylinder engine.
There are some who prefer the M/T, but an A/T is the choice for most. The A/T is nearly bullet-proof and with care could last a long time.
The 2.6L (4 cylinder) short wheelbase (SWB) or 2-door was sold here from the early '80s until '89 (I think), but the SWB 3.0L (6 cylinder) was sold only in '89 and '90, with most in '89. I've only heard of one '90 model on this forum.
Thee are many issues much worse than timing belts, but if you eliminate a SWB because there might be something wrong with it, you'll never find one to buy - unless I decide to sell mine, and that ain't happening anytime soon...... check with my wife after I'm dead. <img src="/forums/images/graemlins/oink.gif" alt="" /> Find one with a good body for a reasonable price and plan to spend some money on it.
6'4" is pushing it for a Raider/Montero, but at least there's plenty of headroom. Some have changed the seats, but that's a personal preference. If you want to change things, you should plan to spend some time taking measurements and custom fabricate a lot of it yourself to avoid unreasonable expense.
If you can find the right truck at a reasonable price and put some sweat equity and money into it, you'll probably get a lot of use from it for a long time. If you decide to do that, you'll find this forum very helpful.
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019299 01/27/11 06:21 AM
Welcome! Franks definitely knowledgeable about these rigs... And I agree with everything he's said thus far.
One added insight as far as automatics go is the 90/91 auto (either with the 2.6 or 3.0 L engine) has a lock-up torque converter while the earlier models were not. The lockup variety will net you better mileage.
Also the 2 doors were available as early as 84 in the US (essentially the 1983 pajero) and stopes being sold in 1990. The 4 door gen I's were sold from 89-91.
I've owned both and fortunately have not had to spend too much to maintain my 89 2 door v6. I had to replace the coolant overflow tank & rear window latch.
My pwr steering unit leaks fluid but I rarely use it so fixing that is not a high priority.
My auto tranny fluid aux cooler lines wore through at the bracket but was easily fixed with high temp rtv hoses, and clamps.
Other than that it's been very reliable and is now at 180k miles.
My old 4 door 1990 had well over 200k before I let her finally go to another forum member rxinhed.
HTH. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: FrankR] #1019300 01/27/11 06:27 AM
L
LeeForget Offline
What you need to keep in mind the most is there is no aftermarket community for this vehicle, this forum on this website is pretty much the whole community. So if you want to change things, you'll either have to custom fab them yourself or pay someone else to custom fab it. There isnt much out there. That being said, regular repairs are decently cheap as dodge/mistu put these motors in a lot of vehicles. They are bad for head gaskets and warped heads in the 4 cyl, as well as jet 0rings (burning oil). Dont expect a power house out of a 22 year old engine that originally only had 110 hp as well smile With alllll that said, my raider is the best 500$ ive EVER SPENT IN MY LIFE. All of my friends drive jeeps, samarai's, trackers, land cruisers, land rovers, toyota's, ect, and they all love my raider, almost as much as i do.
~88 Raider 2.6L 5 speed
~35"x14.5"r15
~SOA(Spring Over Axle)
~TT(Torsion Twist)
~SBL(Sloped body lift)
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: LeeForget] #1019301 01/27/11 06:37 AM
jacumja Offline OP
LeeForget
My first vehicle was a pull behind rv Sammy with a whopping 55 horse power. I like the speed for torque exchange it keeps my insurance low with the lack of tickets. Thank you for your input so in your opinion I should stay away from the 4 cylinder unless I want issues. I found this guy on Clist, he seems like a guy that loves the Raider maybe someone knows him. My favorite vehicle was the sammy but its just to small. When I owned one I was 6 to 8 inches shorter but now I can't squeeze my ass in it regardless of how far back i move the seat. Def designed for an Asian driver and not an American raised on fried chicken and whole milk.
http://sfbay.craigslist.org/eby/cto/2180698198.html
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: LeeForget] #1019302 01/27/11 06:48 AM
I paid $1K for my 87 Raider about 5.5 years ago with 84,500 miles. Now at 182K+ miles, the engine is making pretty healthy blowby, can't climb the hills like it used too, timing chain clatters a little, and the valve lash adjusters are complaining some until everything warms up. I have driven the snot out of the little truck, exceeding the GVW often, towing big and little things, loading it up to the eye balls. Greatest little vehicle!
I like them so much, that I 'store' parts and vehicles for this board and members at the figuratively called "Montero Ranch" and make enough for lunch expenses and sometimes other parts.
Russell the Raider Guy
aka 'rxin hed'
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: FrankR] #1019303 01/27/11 07:07 AM
jacumja Offline OP
FrankR
Thank you also for your response I live down in Myrtle Beach. So if I go through with this I'll bother you a lot with questions.
I'm guessing by "fixed that" you mean strapping a super charger on to it. I'm not really advanced enough for all of that. As far as the drop in turbo option. I'm guessing your talking about the Starion/Conquest set up. From what I've read it requires alot to "drop in" along the lines of fabbing. Was that set up really awesome or something? I think it'd be a lot easier to make some upgrades and super charge the 6 like you did. Call me stupid but they're has to be a swappable motor for that 6cylinder block a diesel I've seen but what about the 3000gt power plant that would be a helluva lot easier to find that the Conquest set up.
Also seems like the 6 was made a bit better and easier to add lockers and lift to if my research is correct. You do say the Automatic tranny is tuff though?
Seems like my legs would be fine if I simply downsized that steering wheel. That was really my only issue and I'm sure I can move the seats back an inch or two if needed or add seats from newer montero's.
I have my heart set on a black v6 auto with the tan interior but it seems pretty unrealistic. I may have to do some painting because it seems like there aren't many around.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019304 01/27/11 07:08 AM
L
LeeForget Offline
im not saying to not get a 4 banger, but if you have the option between a 4 banger and a v6...well...the obvious choice is right in front of you. But if your chosing between a 4 banger in good shape and a rotten v6,choose the 4 banger.
~35"x14.5"r15
~TT(Torsion Twist)
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: off-roader] #1019305 01/27/11 07:24 AM
jacumja Offline OP
Thanks guys so much it seems like most of you are on the west coast so I'll get plenty of late night info. I'm a big fan already of this community but not a big fan of the functionality of this board, its a bit different. I wanted to post a link to the vehicles I've narrowed it down to. The guy selling has 2 of em and another in need of some work. His 4 cylinder is built but also has some rust through the body which I'm not a fan of. Pics are at the tail end of the thread.
http://www.nc4x4.com/forums/showthread.php?t=101532&highlight=raider
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019306 01/27/11 12:47 PM
FrankR Offline
Yes.
Yes.
I've never done one, but it seems fairly straightforward once you have the correct engine and the required parts. I would imagine that adding the intercooler is the majority of the needed fabrication. Read the Turbo Bible thread and ask others who have done the swap.
Yes - about 200HP with enough boost.
Not a chance. It would be nice if it were true - but if it were true, you'd see a lot of supercharged Raiders running around.
There are no "drop-ins". There are engines that will fit, but all require a considerable amount of work. A very good choice would be a Chevy 4.3L, but it's major work.
It can be done and would be a good choice, but be aware that there are some clearance hurdles to overcome.
Quality is the same - the drive train is slightly stouter on the 3.0L., but they're close enough that I wouldn't call one a lot better.
It holds about 225HP and around 250 lb-ft of torque just fine for me.
The '89 3.0L has a tilt wheel that swings upward and gives more leg clearance. I don't know if the earlier models had that feature.
Again, buy the right truck at the right price - that means NO RUST. They are available in SC. Then plan to spend some time and money to make it into what you want.
Frank
PHP: 7.4.33 Page Time: 0.028s Queries: 16 (0.025s) Memory: 0.6593 MB (Peak: 0.8078 MB) Data Comp: Off Server Time: 2026-11-20 00:44:41 UTC
