Page 3 of 4 1 2 3 4
Re: Misfire?Cat clogged? Something else? [Re: TerraXpeditions] #1019694 02/15/11 09:35 PM
Sorry, 95 Montero SR 3.5... I'm used to having a signature in other forums.
You can have a signature here... click on MY HOME above.
Scroll down to the Main Configuration section and click on the Edit link for Your Information and scroll down and edit your signature. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Also, no, it's not OBDII. There's a proceedure in the FSM to read the codes but if the Check Engine light is not lit, there won't be any (at least on a gen I).
Confusing.
Had a wild hare to check the plugs again (after finding the plugs loose) and the first coil I pulled out (#2 cylinder) came apart.... put it back together and stuck it in the truck.
Fired up and ran/drove perfectly again. So I must have one or more bad coils?
Even ole Bob's music isn't helping to calm me down today... which is very surprising... grrr
Three little birds. Three little birds.
Hey, at least you've likely found the problem. <img src="/forums/images/graemlins/kewl.gif" alt="" /> If nobody here has a spare coil, you can probably find them at a local salvage yard or car-part.com/msrecycling.com
Re: Misfire?Cat clogged? Something else? [Re: off-roader] #1019695 02/15/11 09:55 PM
TerraXpeditions Offline OP
Thanks Ray.
Anyone here have a spare coil??????????????
Now to find the classifieds for 4x4wire........
Re: Misfire?Cat clogged? Something else? [Re: TerraXpeditions] #1019696 02/16/11 01:22 AM
Back to misfiring
Re: Misfire?Cat clogged? Something else? [Re: TerraXpeditions] #1019697 02/16/11 02:16 AM
Just picked up the coil I had Oreillys order for a "just in case" situation. FYI this is a factory "diamond" part and 100% identical.
http://www.oreillyauto.com/site/c/detail...7&ppt=C0334
Re: Misfire?Cat clogged? Something else? [Re: TerraXpeditions] #1019698 02/22/11 12:04 AM
94Monty Offline
I'm having the same problem with my 94SR. I'm anxious to see if the new coil solved the problem.
94SR 3.5L(AT)factory rear locker 31/10.5R15 BFG M/T
94LS 3.0L(M)30/9.5R15 Falken Wild Peaks
2003 Limited(AT) BFG A/T
Re: Misfire?Cat clogged? Something else? [Re: 94Monty] #1019699 02/22/11 04:50 AM
sasnydley Offline
me too? Misfire when cold. Swapped one coil already with no change- gonna start other 2 now...Results?
Re: Misfire?Cat clogged? Something else? [Re: sasnydley] #1019700 02/22/11 11:25 AM
Sorry guys, I've tried posting multiple times with apparently bad results. Oh well here goes another.
Replacing the one bad coil pack seemed to cure my issues. Did a 600 mile trip this weekend over some very rough terrain and it did admirably well.
<object width="400" height="224" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/592244321091" /><embed src="http://www.facebook.com/v/592244321091" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="224"></embed></object>
Re: Misfire?Cat clogged? Something else? [Re: TerraXpeditions] #1019701 02/22/11 04:45 PM
Winner. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Misfire?Cat clogged? Something else? [Re: TerraXpeditions] #1019702 02/22/11 06:54 PM
Is that supposed to be a picture? I assume it is and if so, the url needs to end in the file format (.jpg, .gif, .tif, etc.).
Also, it also needs to come from a website that allows direct linking to images. Many don't including facebook. Ones that do include webshots, picassa, etc.
HTH. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Misfire?Cat clogged? Something else? [Re: off-roader] #1019703 02/22/11 11:58 PM
Lets try this:
Or
http://s708.photobucket.com/albums/ww89/...nt=100_0078.mp4
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6449 MB (Peak: 0.7701 MB) Data Comp: Off Server Time: 2026-05-29 16:15:51 UTC
