Transmission Cable #1019762 02/03/11 10:11 PM
Jamez Offline OP
It appears all the 4wheelin I've been doing in this record-setting snowfall has taken its toll on the '88. The transmission wouldn't shift until it was warmed up this morning, but being below 0 last night I figured anything and everything that could freeze probably did (along with the brakes). Anyway, took a peek under the hood and the cable is bunched up against the throttle. I'm guessing it broke down by the transmission, but I won't know till this weekend. Couple questions:
Will the cable on the '87 swap over?
Any tricks on removal and replacement? (I do have the FSM and a Haynes, but sometimes those with experience can be more helpful)
I appreciate it <img src="/forums/images/graemlins/patriot.gif" alt="" />
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: Transmission Cable [Re: Jamez] #1019763 02/03/11 10:46 PM
You have to pull the tranny pan to get the old one unhooked and the new one hooked up. Adjustment is critical. Sort of tight getting to the lower end.
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.5912 MB (Peak: 0.6397 MB) Data Comp: Off Server Time: 2026-11-19 23:57:23 UTC
