98 gen 2.5 rear door handle fix? #1019831 02/04/11 06:53 PM
O
OneTime Offline OP
The rear outside handle to my rear door stopped working. I have to open the door from the inside latch. I remember the same thing happening to my 95SR but cant remember how I fix it. Anybody fixed this before? Couldn't find anything with a search.
98 Gen 2.5 w/ winter package & 31x10 BFG ATs.
Re: 98 gen 2.5 rear door handle fix? [Re: OneTime] #1019832 02/04/11 07:01 PM
justice Offline
Not sure about your case but my 95's, used to stick on occasion. The mechanism gets dusty and does not like to return to the normal position. If the part of the handle that you pull on is loose like when you pull on it there is no spring resistance, you might have the same problem. An open palm strike just above the handle sometimes jarrs it loose. Take the inside door panel off and blow out with air, and then lubricate the mechanism.
Re: 98 gen 2.5 rear door handle fix? [Re: justice] #1019833 02/04/11 07:14 PM
O
OneTime Offline OP
cool. thanks
Re: 98 gen 2.5 rear door handle fix? [Re: justice] #1019834 02/04/11 07:15 PM
4xmonty Offline
It might have broken the plastic part that connects the handle
to ths latch.Its easy ro replace
Russ
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: 98 gen 2.5 rear door handle fix? [Re: 4xmonty] #1019835 02/04/11 08:52 PM
O
OneTime Offline OP
ok I have the inside door panel off. The outside squeese handle isnt depressing the rod enough to unlock the latch. Where do I go from here. Also the outside squeeze handle is free with no resistance.
I clean and lubricated the spring. No change. Any needed to take off the outside handle? Or maybe a new spring?
Re: 98 gen 2.5 rear door handle fix? [Re: OneTime] #1019836 02/04/11 10:11 PM
Worn/missing bushings in the linkage? Any apparent loose spots in the linkage? Something is soaking up the motion before it gets to the latch.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6132 MB (Peak: 0.6828 MB) Data Comp: Off Server Time: 2026-11-02 21:49:11 UTC
