Isuzu Archives #1020788 02/15/11 04:34 AM
I
isuzu95 Offline OP
A few posts I made ended up there. Unable to locate Isuzu Archives. Nothing intuitive seems to be available.
Moderators - could you post a link/URL?
Thanks.
Mike Murrell
'95 Rodeo - 3.2 liter - 2WD - Automatic
'04 Tacoma - 4 banger - Automatic
Re: Isuzu Archives [Re: isuzu95] #1020789 02/15/11 06:48 AM
kewlynx Offline
Hi, I fished around a little too; no archive per se.
I'm thinking the closest thing to do is to click on your screen name, and view posts.
If they're something you'd like to refer back to later, you can then click on 'toggle thread' (like near the bottom of the page; rather unobtrusive). This then lists the thread as a favorite.
Once that's done, you can refer to them via your 'my home' link at the top.
It's not the most elegant way to do it; but is possible; have you tried using the search link in the header on the page?
**ubi apis- ibi salus**
Re: Isuzu Archives [Re: isuzu95] #1020790 02/15/11 07:53 AM
4x4Wire Offline
The Archives were merged with the Isuzu 4x4 and Talk a couple of months ago.
They were not deleted. Try doing a search for the content.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Isuzu Archives [Re: 4x4Wire] #1020791 02/15/11 04:29 PM
I
isuzu95 Offline OP
Went to 4x4 & Talk - no pointer to archives???
Mike Murrell
Re: Isuzu Archives [Re: isuzu95] #1020792 02/15/11 08:46 PM
Jim_Paget Offline
The Isuzu Archives are no longer available. The individual threads were moved by the Administator into either the Isuzu Talk or the Isuzu Tech, depending on his reading of the thread. You can do a search on all the Isuzu forums by date and content.
If you can't find what you are looking for, post back what the thread was about and I will see if I can find it.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Isuzu Archives [Re: Jim_Paget] #1020793 02/16/11 12:11 AM
I
isuzu95 Offline OP
Jim - I see that SEARCH goes back 5 years - no more - what I wrote up was likely moved there over 5 years ago so it's gone.
Thanks.
Mike Murrell
Re: Isuzu Archives [Re: isuzu95] #1020794 02/16/11 04:53 AM
mlclark Offline
Isuzu Moderator
Here ya go!
LINK
Just leave the date range blank. It will then go further.
Re: Isuzu Archives [Re: mlclark] #1020795 02/16/11 07:03 AM
4x4Wire Offline
There are actually TWO search options.
One is the standard forums search which by default is indexed at 5 years. However, you can trick the system to searching older dates as noted.
The second is the Custom Google search which will pick up ALL dates.
In the google search, it will search ALL 4x4Wire content (forums, portal and archive) before reaching out to the internet.
You do need to be a little specific with the keywords used for search.
John Stewart
Editor - 4x4Voice
Re: Isuzu Archives [Re: mlclark] #1020796 02/16/11 06:07 PM
I
isuzu95 Offline OP
Thanks to all for your effort.
The LINK Michael Clark provided stops in Feb. '06 - 5 yrs. ago.
I give up - not that important.
Mike Murrell
Re: Isuzu Archives [Re: isuzu95] #1020797 02/16/11 07:00 PM
4x4Wire Offline
For clarification, under the standard forums search, you can specify a date range to search.
Check the lines "Newer Than" and "Older Than"
In newer than, enter 10 and for the drop-down menu, select "years"
In the older than, enter 5 and for the drop-down menu, select "years"
You will need to enter a keyword and/or username.
That will give you all posts between 5-10 years ago.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6372 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-10-21 19:47:55 UTC
