Fuel gauge receiving unit #1020988 02/18/11 12:48 AM
Snowtoy Offline OP
Anyone know if it is possible to repair a fuel gauge receiving unit? I have an '84 22re 2wd truck that I have been restoring, the only thing left is the fuel gauge. Originally thought it was the sending unit, but it tests correctly. I pulled the cluster and checked the receiving unit and it is bad. Toyota no longer manufactures the part(#83243-89308), nor does any after market manufacturers. I haven't been able to find any clusters at the parts yards, forums, or on ebay, and according to Toyota the part was only used for '84-'86 trucks, so swapping in one from a celica, cresssida, supra, etc., wont work.
My current options are replacing the cluster w/a std. one and adding a tach, or installing an after market sending unit/float/gauge. Before going this route I figured I would see if there isn't a way to fix the current sending unit.
Re: Fuel gauge receiving unit [Re: Snowtoy] #1020989 02/18/11 02:00 AM
G
Greg_Canada Offline
I'm sure if you put a wanted post up on yotatech for an 84-88 SR5 cluster someone can find one for you.
Or, check car-part.com for "instrument clusters" or "speedometers" and i've already found more than a few of them in about 30 seconds.
89 4Runner
Re: Fuel gauge receiving unit [Re: Greg_Canada] #1020990 02/18/11 03:01 AM
Snowtoy Offline OP
I didn't try car-part.com site directly, the Olympic 4x4 site I usually use has a car-part.com used parts link and it turned up nothing. I will take a look at the site, thanks.
Re: Fuel gauge receiving unit [Re: Snowtoy] #1020991 02/18/11 03:11 AM
Snowtoy Offline OP
My luck must be turning, I found two and found another just posted on pirate.
Still would like to know if the receiving unit can be fixed, it would be nice to recoup some cash.
Re: Fuel gauge receiving unit [Re: Snowtoy] #1020992 02/18/11 04:02 AM
kewlynx Offline
I'm guessing you'll be the first to tell us. <img src="/forums/images/graemlins/wink.gif" alt="" />
Have you had a chance to look at an EPC to see what all that might look like? That's what I do if taking the plunge with something new and no guidance.
**ubi apis- ibi salus**
Re: Fuel gauge receiving unit [Re: kewlynx] #1020993 02/18/11 08:22 AM
KiwiCowboy Offline
There's not a lot to a fuel guage that can go wrong. Dirt and rust are the main culprits I find and a good cleaning usually fixes them.
Re: Fuel gauge receiving unit [Re: KiwiCowboy] #1020994 02/18/11 09:20 AM
kewlynx Offline
Yeah, I think we had that discussion about gauge grounds being crudded up not too long ago. Even more so with an older rig.
Re: Fuel gauge receiving unit [Re: kewlynx] #1020995 02/28/11 01:37 AM
Snowtoy Offline OP
Do you mean EPC as in electronic product code?
Re: Fuel gauge receiving unit [Re: KiwiCowboy] #1020996 02/28/11 01:42 AM
Snowtoy Offline OP
There's not a lot to a fuel gauge that can go wrong. Dirt and rust are the main culprits I find and a good cleaning usually fixes them.<img src="/forums/images/graemlins/kewl.gif" alt="" />
No rust or dirt on the receiving unit in the cluster, the copper is nice and bright, no tarnish on the screws either. This is what it looks like.
Re: Fuel gauge receiving unit [Re: Snowtoy] #1020997 02/28/11 03:01 AM
4Crawler Offline
Electronic Parts Catalog, CDROM w/ factory part numbers and diagrams.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6398 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-07-09 16:14:26 UTC
