wheels, tires, gears #1021074 02/18/11 05:56 AM
chrisg_sdcf Offline OP
Anyone with 35, 36, or 37" x 14.50 tires how much backspacing do your wheels have? Also do you have 10" or 12" wheels?
How about gears? Did you re gear with 4.56, 4.88, or 5.29?
Thanks
Chris Griffith
Re: wheels, tires, gears [Re: chrisg_sdcf] #1021075 02/19/11 02:18 AM
Kookadala Offline
There should be a ton of info on these topics if you search. I have 35s with 4.88 gears, thats about as close as you can get to keeping the speedometer accurate. Lower gears (5.26) will make it harder to use your truck on the freeway.
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: wheels, tires, gears [Re: Kookadala] #1021076 02/19/11 02:23 AM
thanks for the info, I have been searching for a while now the only stuff I could find on 35" tires was how much lift was needed to fit them and whether or not you needed to hammer the fender. Also I couldnt find anything on gearing for 35" tires. Maybe Im just using the search wrong, sorry if it upset you.
Thats what she said
Re: wheels, tires, gears [Re: Kookadala] #1021077 02/19/11 02:24 AM
oh also how wide are your 35" tires if you dont mind me asking
Thats what she said
Re: wheels, tires, gears [Re: chrisg_sdcf] #1021078 02/19/11 02:32 AM
Kookadala Offline
standard 35x12.5x15
Re: wheels, tires, gears [Re: chrisg_sdcf] #1021079 02/25/11 07:10 AM
adam Offline
I've run 35 & 36 x12.5 (x15) and 37x13.5 with 4.88s and a 5 spd, always found it to be a good match.
The wheels are Champion beadlocks, must be 10s, which makes them more like an 11 when Champion sets them up to accept the lock ring. They were a secondhand offering, and I've never had occasion or need to take the specs. If I had to guess I'd say they're 3.5" backspacing. I whack the snots out of my fenders with what's a sagging 5" sas (36s fit well when the springs were fresh), but they still don't bind on the steering, suspension, or frame.
~Adam
Re: wheels, tires, gears [Re: adam] #1021080 02/26/11 06:46 PM
Thanks for all the info. I think Ive got everything figured out except what backspacing I need.
Thats what she said
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6177 MB (Peak: 0.6917 MB) Data Comp: Off Server Time: 2026-10-24 03:23:08 UTC
