Gen II ?s #1021163 02/19/11 03:28 AM
leadheavy52 Offline OP
Hello all,
Due to expanding family, and trouble passing emmisions, I decided it best to part ways with my beloved 88 SWB. After over a year of always proving that Mitsu built one od the most legendary 4X4's 9and proving Jeep guys wrong), I decided that my next purchase would be a nice Gen II. After month's of looking for the right one, I settled on a 96' LS, the no-frills package. I looked for an SR, but found none that were in need of a fair amount of work to be the type of vehicle I was ready to spend money on. Also, the 3.5l DOHC scares me in these vintage trucks. So I found a VERY well maintained example. All service records kept and all scheduled maintenance done on par with the book. So I bought it. Now I have a few questions.
1. The A/T seems to shift at 2.7-3.2k exery shift but fourth. Is it normal for it to shift this high, with normal driving of course.
2. I have what sounds like a very slight chirp at the A/C when the compressor is turned on, but dissapears when the A/C is in the off position. Is this something that I need to replace, or will a little bit of grease on the backside of the pulley work?
3. Would it be easier to install an ARB locker for the rear, or source a SR axle and use the factory components?
Thank you for your help. By the way, here are two pictures. One of the old, and one of the new(er).
1988 SWB Montero - 2.6L - 5-speed
Weber Carb
(Coming Soon) Rugged Ridge AVM Hubs
Re: Gen II ?s [Re: leadheavy52] #1021164 02/19/11 03:54 AM
My 95 LS was pre-wired for the locker. Pull the filler cap in your console where the R/D Lock switch would be and see if there is a connector there. Also, the control module goes in the rear cargo DS side behind the panel. Ditto there on the connector. Lastly, there is a connector in the PS smuggler's cubby for the compressor. If yours is pre-wired, finding an SR rear would definitely be the way to go. Make sure you get the drive shaft from the donor.
Re: Gen II ?s [Re: leadheavy52] #1021165 02/19/11 04:07 AM
monte3 Offline
The chirp could be a belt that needs to be adjusted.
Curious, what wheels are on your Gen 2?
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: Gen II ?s [Re: monte3] #1021166 02/19/11 04:40 AM
L
Lesharoturbo Offline
Those look like stock alloys to me, mine has the exact same (it's the same colors too!)
94 LS 3.0
Re: Gen II ?s [Re: Lesharoturbo] #1021167 02/19/11 08:23 PM
Correct, those are the stock wheels. Also, if I were to source an SR rear axle, I would also need the front gearing as well since they are different. Is this correct?
Weber Carb
Re: Gen II ?s [Re: leadheavy52] #1021168 02/19/11 09:34 PM
Depends on what you have now. There should be a tag under the hood with a 4 digit number on it. SR will be 4636, gen1's were 4625, you may have 4222 or 4636, or even a rara avis 4875. You're gonna miss the 36hp diff between the 3.5 and 3.0, but not an insufferable amount.
I think there were lsd gen2's, too, and that's almost as good as a locker, just not as sexy.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6827 MB) Data Comp: Off Server Time: 2026-05-29 19:54:04 UTC
