Front LSD #1021269 02/21/11 10:49 PM
8
87Raider Offline OP
Did they make a front LSD in an 87? If not what would work in it? Thanks Mike
Re: Front LSD [Re: 87Raider] #1021270 02/22/11 12:09 AM
hazy_daze Offline
No LSD or traction aid of any kind was offered from the factory, in any year, Montero or Raider. Others have swapped in an LSD from a Starion or Conquest. It has been discussed quite a bit. Several people have done very detailed write-ups on it. Do a bit of searching and you should turn up a good amount of reading material that'll point you in the right direction. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
EDIT: Here's the write up that I was referring too.
Re: Front LSD [Re: hazy_daze] #1021271 02/22/11 03:25 PM
W
willwinchforfood Offline
Isnt the 87 Monty the oddball trying to figure out which starion LSD to use?
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Front LSD [Re: willwinchforfood] #1021272 02/22/11 04:11 PM
Given how the swb shudders in a tight turn with a rear lsd, I'd want to reduce the preload on the lsd in the front, maybe take out some plates/friction discs, or add more friction modifier to make it more slippery. Search under KevinC and front lsd for a writeup he did several years ago.
Re: Front LSD [Re: fasteddy] #1021273 02/22/11 09:49 PM
87monty Offline
Im waiting on some parts for my front Tsi LSD swap (Which I have) with a little change of direction, But If it all works out I will let you know..
As for the comment above an Odd ball can be a good thing <img src="/forums/images/graemlins/cyclops.gif" alt="" /> Like Turbo monteros pssst
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-06-17 13:41:03 UTC
