is my '99 Rodeo worth keeping or should I dump it? Advise please #1021534 02/24/11 04:30 PM
Celeste17522 Offline OP
I have a '99 Isuzu Rodeo 4WD, almost 142,000 miles. I just took over the maintenance on it from my ex in November, and have replaced the master/slave cylinders and front brakes so far. I suspect it has a clogged radiator and MAY need a new alternator. I'm just a not so car savy girl, I know a little, but not enough-LOL. In your opinions, is it worth working on the small things and keeping my Rodeo, or should I cut my losses and get rid of it before it nickle and dimes me to death?
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: Celeste17522] #1021535 02/25/11 04:47 PM
BigSwede Offline
If the major components (engine, tranny) are sound, I would keep it. Much cheaper than a car payment. Radiator and alternator are pretty easy DIY projects so they aren't too expensive.
Just keep a close eye on the oil level. That motor does not work well with low oil.
Serenity now!
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: Celeste17522] #1021536 02/25/11 05:13 PM
87Montero Offline
You could just get another date that's good at turning wrenches. <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: 87Montero] #1021537 02/26/11 02:05 AM
Jim_Paget Offline
Look. A new user came here for our help. Rather than responding in a helpful way, you chose to reply with a sexist response that is unacceptable on this site.
Consider this as your final warning.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: 87Montero] #1021538 02/27/11 01:53 PM
Great idea! Unfortunately, HE was the one who didn't check the fluids, have the oil changed ever, and wore out my clutch. I tink I'll stick to taking care of things myself! Apparently, not all men ARE created equal smile
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: Jim_Paget] #1021539 02/27/11 01:55 PM
I appreciate your response. Some people are very quick to judge.
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: Jim_Paget] #1021540 02/27/11 03:44 PM
87Montero Offline
My apologies to the original poster and everyone else then for it coming across that way... No offense was meant in the first place.
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: Celeste17522] #1021541 03/01/11 06:53 AM
kewlynx Offline
Hi Celeste, welcome to the Wire; bit slow in the Zu section here, but you can always find help.
Click on the Isuzu section above in the header for other little tech articles related to your ride and familiarize yourself a bit.
Probably wouldn't hurt take a look at what kind of shape your CV boots are on the front axle for the heck of it, esp if you're already looking to get the rig on YOUR maintenance schedule.
PS: Regarding the alternator, if there's an electric automotive rebuilder in your area, yank it and let them replace the brushes and stuff for you. That way you get to keep the OEM armature. I do this with my Toyota alternators and starters.
**ubi apis- ibi salus**
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: Celeste17522] #1021542 03/01/11 09:39 PM
pinoy99 Offline
imo, get rid of the truck while it has value
unfortunately there might not be much demand for it but can be traded for a another car/truck
might want to checkout planetisuzoo as its forum seems to get more traffic now
good luck
Re: is my '99 Rodeo worth keeping or should I dump it? Advise please [Re: pinoy99] #1021543 03/02/11 05:39 AM
jeffs_62 Offline
While I will submit, Isuzu's are not the easiest vehicles to work on, and some parts are hard to find and expensive when you do. I would have to point out, that any vehicle that you may end up with after trading the one in that you already have, may be in the same or worse condition. If you are at all interested in keeping it, I would suggest that you do. If you have specific problems that you would like help with just post up and the Zoo community will be happy to help.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6322 MB (Peak: 0.7405 MB) Data Comp: Off Server Time: 2026-06-21 20:24:38 UTC
