RADIATOR ON '99 WITH AUTO TRANSMISSION #1021554 02/25/11 11:13 AM
BAZINGA Offline OP
Having taken the radiator out, I failed to take note of which line from the auto connected to the radiator. One of the lines runs through a loop of metal tubing at the bottom.
Does it matter which one goes where? <img src="/forums/images/graemlins/confused.gif" alt="" />
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: BAZINGA] #1021555 02/25/11 06:33 PM
Uh Oh
Hate it when that happens....
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION #1021556 02/26/11 01:55 AM
BAZINGA Offline OP
Uh Oh
what do you mean? Now i'm worried
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: BAZINGA] #1021557 02/26/11 06:16 AM
hadtomer Offline
hello
well- i dont know about the correct hose order-but i would take the time to upgrade to an external oil cooler. mine works great.
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock.
http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: hadtomer] #1021558 02/26/11 09:58 AM
BAZINGA Offline OP
Already paid for a new radiator.
I just need to know what tube goes where (if it matters)
Where did you install the external oil cooler?
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: BAZINGA] #1021559 02/26/11 07:36 PM
hadtomer Offline
first of all - fitting a new radiator is not a reason not to fit an oil cooler. 2 different things. as far as i can tell-the external oil cooler works really well. how do i know? - well-my right leg doesnt get cooked when i drive in the summer. as for fitting- i bought an oil cooler for an equivalent of 30 $ - its a universal kit that comes with hoses etc. size? i went for the largest i could find- so its size is roughly the size of a shoebox lid.
now-fitting it is the tricky bit-you will have to fit it behind the front bumper and in front of the aircon radiator. how does it fit? the kit comes with these plastic rachet things that hold it in place in front of any radiator. and another thing-i fitted it behind the aircon fan. in order to do that i put some small spacers on the 3 bolts that hold the aircon fan in place-thus extending the fan about 1 cm forward. why? because now when i turn the aircon on the fan also cools my oil cooler. i will be glad to take some pics-but its in a really bad location behind the bumper. in total- 2 hours work. 30-40$ (i dont know the price in the USA) and it works.
p"s- dont forget that the main target of the cooler inside rad is to make your trans. oil heat up faster-so i guess if u live somewhere cold it does make some sense.
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: BAZINGA] #1021560 02/26/11 08:25 PM
DennisThompson Offline
Ok, for your original question, I don't think it matters if the fluid goes in forward or backward but if you get them differant than when you took it apart it might look funny. I have noticed that most hoses and wires fall in there natural position. Mine is a stick so I can't go look at it to see which hose goes where, maybe somone with an auto can look for you.
Dennis
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: DennisThompson] #1021561 03/06/11 05:56 AM
BAZINGA Offline OP
Well, I got the new radiator. You were right about the hoses falling back into their original shape. The car nows runs nice and cool.
Interesting point: I took the radiator down to a local engineering shop and because it is an aluminium core, he couldn't fix it. One of the annoying things about this (yes there are several), is that the radiator was only 3 years old and I have always put in the additive. The last original lasted 8 years. So I got some metal putty and plugged the hole. Traveled 700km's before swapping over. I have full confidence in the putty working. I have used it to repair cylinder heads before. Anyway, he said that he had a similar problem with his Landcruiser. He said the because the radiator is mounted on rubber bushes, it doesn't earth properly. I checked it and sure enough, the volt meter showed 0.25 volts. So I have now made an earth strap so my radiator will last for many more years.
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: BAZINGA] #1021562 03/06/11 03:38 PM
hadtomer Offline
can you plz pot a picture of the earth strap? and how doe this connect ti the leak? (im asking becayse my rad was replaced 3 weeks ago after 1 year!!!)
also - is that manifold in the picture for the sporty??
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: hadtomer] #1021563 03/07/11 12:29 AM
DamKia Offline
Kia Moderator
The earth strap is simply a piece of wire that makes good contact with the metal of the radiator and good contact with the body of the vehicle. Basically a piece of wire with two lugs crimped on the ends connecting the radiator to the body - it is as simple as that.
The earth strap does nothing to correct the leak - that still needs to be fixed, but what it does do is prevent the corrosion that can cause further leaks to occur.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6404 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-05-29 16:41:04 UTC
