HELP! I'm leaking blinker fluid.
#1022351
03/07/11 07:12 PM
Trash guy decided to return the trash can to the middle of the driveway this morn, totally ruining my "back out of the driveway without even looking" perfect track record.
Anyone have a passenger rear tail light from a parts rig they wanna get rid of?
=Brian= 96 T-100 4X4 XCab 5-Speed 46 Willy's CJ-2A
Re: HELP! I'm leaking blinker fluid.
[Re: Chemical442]
#1022352
03/08/11 06:50 AM
Best bet might be the junkyards; www.car-part.com, or fleabay.
[Re: kewlynx]
#1022353
03/10/11 09:54 PM
I've had good luck with both for the same parts (1 each)... Oddly my tail light fixture has been leaking fluid, water - not sure how it is getting in there, but I gave up trying to keep it our and replacing lightbulbs and drilled some drain holes. So far, so good...
[Re: Scott Broam]
#1022354
03/12/11 03:56 PM
I've had good luck with both for the same parts (1 each)... Oddly my tail light fixture has been leaking fluid, water - not sure how it is getting in there, but I gave up trying to keep it our and replacing lightbulbs and drilled some drain holes. So far, so good... It's probably cracked along the top edge or on the back. Take it off and fill it with water. The leak will show you where the crack is. <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6052 MB (Peak: 0.6604 MB) Data Comp: Off Server Time: 2026-05-29 22:31:46 UTCValid HTML 5 and Valid CSS
