HELP! I'm leaking blinker fluid. #1022351 03/07/11 07:12 PM
Chemical442 Offline OP
Trash guy decided to return the trash can to the middle of the driveway this morn, totally ruining my "back out of the driveway without even looking" perfect track record.
Anyone have a passenger rear tail light from a parts rig they wanna get rid of?
=Brian=
96 T-100 4X4 XCab 5-Speed
46 Willy's CJ-2A
Re: HELP! I'm leaking blinker fluid. [Re: Chemical442] #1022352 03/08/11 06:50 AM
kewlynx Offline
Best bet might be the junkyards; www.car-part.com, or fleabay.
**ubi apis- ibi salus**
Re: HELP! I'm leaking blinker fluid. [Re: kewlynx] #1022353 03/10/11 09:54 PM
Scott Broam Offline
I've had good luck with both for the same parts (1 each)... Oddly my tail light fixture has been leaking fluid, water - not sure how it is getting in there, but I gave up trying to keep it our and replacing lightbulbs and drilled some drain holes. So far, so good...
96 T100 Titan Xcab V6 2WD,Powertrax No-Slip Diff, buckets, mini-mods...
http://picasaweb.google.com/scott.broam/TruckProjects#
Re: HELP! I'm leaking blinker fluid. [Re: Scott Broam] #1022354 03/12/11 03:56 PM
BamZipPow Offline
It's probably cracked along the top edge or on the back. Take it off and fill it with water. The leak will show you where the crack is. <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6014 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-10-21 19:17:47 UTC
