swap the motor or the body? #1022411 03/08/11 01:39 PM
TexJeff87 Offline OP
I've been mulling my options here. Tell me what you would do.
The wrecked truck has the better engine and all the suspension mods done.
Then new truck has the body, but the motor is very tired and the suspension is...well it's a stock 87, ya know?
I know that I could swap the engine, and move the suspension parts over when I can save up the $$. But then I thought, what if I just put the straight body on the modified frame?
How hard is a body swap, really?
Thanks in advance.
If Mad Max had a 4runner...
Re: swap the motor or the body? [Re: TexJeff87] #1022412 03/08/11 04:51 PM
G
Greg_Canada Offline
body swap is easy if you've got a lift.
89 4Runner
Re: swap the motor or the body? [Re: Greg_Canada] #1022413 03/08/11 11:56 PM
toyrunner Offline
Thanks in advance.
Easy as pie!
Or, a few friends, not hard at all. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: swap the motor or the body? [Re: toyrunner] #1022414 03/09/11 03:09 AM
OK, since you seem to be types who have done it, what do I need to look out for? Any gotchas?
Re: swap the motor or the body? [Re: TexJeff87] #1022415 03/09/11 03:25 AM
kewlynx Offline
Once you're ready to lift it off, check EVERYTHING TO MAKE SURE IT'S ALL DISCONNECTED:
Steering wheel disconnect in engine compt.,
Brake/clutch hoses in engine compt
Shifters removed
Exhaust (pick yer spot)
Tank filler hose
Any wiring/hoses attached along the bottom
All body mounts etc.
Remove the wrecked body first, and give the frame and everything a good going-thru, esp where the fuel tank rests against the frame; that seems to be a problem area. Do repairs/cleanup as needed. Make sure it's a ROLLING frame. The engine/tranny do NOT need to come out at all.
If you feel you'd like to have a fresh clutch job, this is the time to break it all loose. Same for ujoints.
I haven't done a 4R, but have done a cab swap on a truck. Using an engine hoist would be pretty tough on a 4R chassis; what I would suggest is rounding up 6 jackstands and some 2x6s or 2x8s for cross supports, along with whatever other dunnage you need to get it all high enough to clear (hence removing the shifters), roll the frame out from beneath one, and under the other.
Inform your help that the beer WILL stay on ice until you're done.
Bleed brakes/clutch, make sure you're happy with how the steering column lines back up, etc, etc, Good to go. The only thing that won't match now is your VIN on the data plate and the frame, so check what needs done for a clean swap.
Good rolling frame? Dingding-- new trailer. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6104 MB (Peak: 0.6755 MB) Data Comp: Off Server Time: 2026-10-24 23:55:26 UTC
