Sportage starting problem #1022589 03/11/11 03:22 PM
bobcat Offline OP
I have a 1998 Kia sportage that died on my son. I am able to get it to start after 30 seconds of cranking, but when you drive it, it dies. We changed the fuel filter,nothing. I noticed that the fuel pump relay contacts doesnt kick in until you actually crank the engine. Don't know if that is normal on a kia. It idles great when you get it started. Any ideas where to start?
Re: Sportage starting problem [Re: bobcat] #1022590 03/11/11 08:11 PM
bobcat Offline OP
ok, towed it to autozone and the only code in it was for the throttle positioning sensor. I replaced it, and it still will not start. I pulled the fuel line off and cranked it and it seemed to be throwing a good pressure of gas out, but I still cant get it to start normally. Now it has a miss
Re: Sportage starting problem [Re: bobcat] #1022591 03/11/11 08:43 PM
homerdog Offline
check and see if the timing belt hasn't jumped a tooth or three
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: Sportage starting problem [Re: homerdog] #1022592 03/17/11 10:01 PM
bobcat Offline OP
ok, checked the timing and it is fine. It still takes about 20 seconds to start, and when you drive it and let off the gas, it dies. I am noticing what smells like old gas, however we had just filled it up the morning before this started. when it idles you can see a miss. i have replaced plugs, wires, fuel filter, and now checked the timing. I'm lost, help please.
Re: Sportage starting problem [Re: bobcat] #1022593 03/18/11 05:13 AM
You replaced both Coil Packs as well as the cables?
How about your air filter? Don't think I have even done mine..hmmm....think I will be checking that out.
Let me know.
Re: Sportage starting problem #1022594 03/18/11 11:25 PM
bobcat Offline OP
ok, heres an update on my ner ending battle. Spoke to a kia tech today who said it was timing, cam or crank sensor. I tore it back down and checked the timing once more. perfect. Replaced the cam sensor, nothing. I hate to buy a crank sensor if that isnt it, because they wont take it back. would that do what i am explaining? cranks for 20 seconds then slowly starts firing until it starts? when it idles there is a slight miss.
Re: Sportage starting problem [Re: bobcat] #1022595 03/19/11 12:00 AM
I take it that it is not throwing any codes?
Re: Sportage starting problem #1022596 03/19/11 03:22 AM
bobcat Offline OP
nope. only code was the tps, which i found was due to a faulty connector.
Re: Sportage starting problem [Re: bobcat] #1022597 03/26/11 04:16 PM
menotthat Offline
dont know if you have fixed the problem yet, but have you
checked the compression? (low compression will require longer cranking)
checked the air filter?
looked at the exhaust coming out?
Try the easy things first.
97 sportage, mostly stock apart from king springs front and rear, monroe shocks, k&n filter, pioneer mp3 cd, rampage 2x 10"subs and rampage amp.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6220 MB (Peak: 0.7038 MB) Data Comp: Off Server Time: 2026-07-14 21:49:25 UTC
