Heated seats #1023280 03/19/11 12:11 AM
A
agerb Offline OP
Hello again, on my recently purchased 1998 Montero the heated front seats are not working. Just about everything else on the vehicle works (including the rear flashlight!) Is there a fuse somewhere or do the elements themselves just give out? Thanks
Re: Heated seats [Re: agerb] #1023281 03/19/11 12:17 AM
Welcome,
I don't have a 98 or I'd be happy to tell you. In case you don't get a quick reply try checking the owners manual, fuse box cover, or download the factory service manual (mitsubishilinks dot com) & check there. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Heated seats [Re: off-roader] #1023282 03/19/11 12:25 AM
A
agerb Offline OP
I will download the service manual, my diagram atop the fuse box cover is no longer legible, and the truck didn't come with any documentation whatsoever. Thanks
Re: Heated seats [Re: agerb] #1023283 03/19/11 05:18 PM
JeffatTireBalls Offline
What flashlight are you talking about? Where is it supposed to be located?
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
Re: Heated seats [Re: JeffatTireBalls] #1023284 03/19/11 05:30 PM
In the toolbox on the back door.
Re: Heated seats [Re: off-roader] #1023285 03/22/11 06:11 AM
ejm Offline
I also have a 98 montero.
Are the seats original? I had a 95 leather seat in mine and the seat looked exactly the same but the seat itself wasn't headed.
There is a black 4 wire plug under the seat that attaches to the heater coils in the seat. Thats how i finally figured it out on mine.
I just found a 98 montero here in Orlando FL. and swapped out a ton of stuff. Including a new HEATED seat. If you need any other small things you may want or need, shoot me an email.
98 Montero, OME lift, Girvin Systems roof rack, Custom Discovery rear ladder 285/75/16 Mickey Thompson MTZ, Cepek DC-1 16x8
Re: Heated seats [Re: ejm] #1023286 03/23/11 01:00 AM
A
agerb Offline OP
THanks, they are the original factory heated seats. I will check all the connections again, see if power is making it past the switch. And as to the flashlight- mine is in the cargo area, driver side rear. Attaches in a little cubby with a magnet and gets its power via the 12 volt lighter outlet back there.
Re: Heated seats [Re: agerb] #1023287 03/23/11 07:06 AM
I haven't ever owned one of the plug in lights, but I do have the battery powered one that fits in the tool compartment in the cargo door. One-upper...mine has Mitsubishi double-A batteries, too, although I doubt they work and I don't keep them in the flashlight. Just showing off.
Re: Heated seats [Re: JohnnyBfromPeoria] #1023288 03/24/11 12:27 AM
My light is the size of a #2 pencil, rides in by left shirt pocket, uses 4A batteries, and the in use mounting bracket is my pie hole, with the aim under perfect remote control...
Re: Heated seats [Re: fasteddy] #1023289 03/24/11 12:34 AM
LRJ4x4 Offline
I'll take a look on my 98 tonight. Heated seats feel so good <img src="/forums/images/graemlins/baby.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6306 MB (Peak: 0.7384 MB) Data Comp: Off Server Time: 2026-06-17 16:42:47 UTC
