Page 2 of 4 1 2 3 4
Re: 1st gen 2.6 lockers? [Re: zarktheshark] #1023409 03/21/11 12:27 AM
8
87RaiderFTW Offline OP
Good to hear there is options. Will the MS axles swap in since my truck uses leaf springs?
Re: 1st gen 2.6 lockers? [Re: 87RaiderFTW] #1023410 03/21/11 12:41 AM
LandRaider Offline
Yes. Montero sports were leaf sprung up until 2000 or so. Thats why it is a direct bolt in to your Gen 1.
Just have to fool with U-joints, and saw off one of the sway bar mounts.
Re: 1st gen 2.6 lockers? [Re: LandRaider] #1023411 03/21/11 12:54 AM
99 was the last leaf spring sport...
Re: 1st gen 2.6 lockers? [Re: fasteddy] #1023412 03/23/11 01:56 PM
haztoys Offline
You all would be shocked at how well a OEM LSD works once its setup and shimed "right" ....I wish someone with pull on this forum would take the bait and send me there LSD to be ajusted ...I'll do it for free...That way you could see what I'm saying ... There really looooooooose from the factory ....There really know need for a locker ...For most people ...
Have a good day
David
Hazardous Toys inc
Re: 1st gen 2.6 lockers? [Re: haztoys] #1023413 03/23/11 02:24 PM
W
willwinchforfood Offline
Will you set up a conquest LSD for the front of my truck? Or do I want to leave it loose for the front end?
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: 1st gen 2.6 lockers? [Re: justice] #1023414 03/23/11 04:51 PM
belijose Offline
you said that there are arb and aussie lockers for the front of the v6? I went to the web page of aussie lockers and for Monteros they only show for the newer models(1998-2009). Would you mind clarifying this issue? thanks
1989 Dodge Raider v6 3.0 L, MT.
Re: 1st gen 2.6 lockers? [Re: belijose] #1023415 03/24/11 12:21 AM
FrankR has one in his swb v6 Gen1.
Re: 1st gen 2.6 lockers? [Re: belijose] #1023416 03/24/11 03:21 AM
KrzyDav Offline
RD 110 ARB
Rocky Road Outfitters
dave h.
Re: 1st gen 2.6 lockers? [Re: belijose] #1023417 03/24/11 04:11 AM
justice Offline
The problem is that most of the manufactures don't know much about the Montero fitment. Half the info on ARB's site is incomplete. In all reality the best way to find out what part number fits what is to ask us. The 8" v6 front diff came in a lot more models than the ARB or Aussie fitment guides list.
Re: 1st gen 2.6 lockers? [Re: justice] #1023418 03/25/11 03:04 AM
Kevin C Offline
Just to add to the list... There was also a very rare aftermarket Torsen rear diff for the 2.6.
The factory rear LSD is a decent part. There was a TSB on it to reduce it's grip to deal with shuddering problems some owners had. If I remember right the fix was replacing / removing a set of clutch plates. It's possible to add extra clutch plates as long as you run the right gear lube (Redline is a favorite). My experience was that most shuddering problems could be cured with the right gear lube and the TSB was not needed.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6433 MB (Peak: 0.7675 MB) Data Comp: Off Server Time: 2026-11-02 21:50:13 UTC
