look what i dragged home. #1023626 03/22/11 04:00 AM
powerRam50 Offline OP
87 raider for 400 bucks.going to use it as a parts truck for both d-50s and the Monty.going to convert the Monty to a stick shift too.i might take the 4.6 gears out of it for the wife's d-50 because it has a LSD,then sell her 4.875 gears.it will be sad to see such a clean raider get scrapped out but the parts will keep 3 rigs in the mud.
Re: look what i dragged home. [Re: powerRam50] #1023627 03/22/11 04:07 AM
Re: look what i dragged home. [Re: powerRam50] #1023628 03/22/11 04:25 AM
KrzyDav Offline
at least it will live again and not go to china to be melted down.
dave h.
Re: look what i dragged home. [Re: powerRam50] #1023629 03/22/11 04:27 AM
I have hacked and parted nicer-type Montys, too. Alas for the individual vehicle. So...answer my question in the other thread: How do I fit 33" muds on my new MM without a body lift or hacking the fenders?
Re: look what i dragged home. [Re: rxinhed] #1023630 03/22/11 04:45 AM
not going to happen.31's will fit if you crank the t bars but depending on backspacing of the rims will rub.mine worked but on the wifes d-50 she had to trim to fit 31's,with cranked t bars.33's will fit with a body lift and t bar lift with out cutting but it will take both.
Re: look what i dragged home. [Re: powerRam50] #1023631 03/22/11 04:49 AM
Hmm. TY <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: look what i dragged home. [Re: rxinhed] #1023632 03/22/11 05:02 AM
maybe doing the montero gen 2 upper control arms,cutting the upper bumb stops,reindexing the t bars then cranking to hell might if you are lucky but it is iffy.i have not tried the gen2 control arms but i want to.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6191 MB (Peak: 0.6930 MB) Data Comp: Off Server Time: 2026-11-03 23:17:28 UTC
