guess these vehicles don't like high water #1025497 03/27/11 02:03 AM
KrzyDav Offline OP
lotta rain here. Thought I'd try out Grampa's pond,,,an low area on a local road that fills up in the spring. About 2 1/2 feet deep , just enough to fill the cabin about 3".
I guess starter motors don't like that much of a drink...
Glad I relocated my ECU a few years back.
dave h.
Re: guess these vehicles don't like high water [Re: KrzyDav] #1025498 03/27/11 10:32 PM
KrzyDav Offline OP
i guess clutch doesn't like it either. Grabby like the clutch on my pops 3 cyl diesel kabota.
dave h.
Re: guess these vehicles don't like high water [Re: KrzyDav] #1025499 03/27/11 11:16 PM
Jamez Offline
I went wheelin with a someone who had a manual Monty years back. He went through some decently deep mud and had chatter/slippage issues after that. I think he ended up cleaning things through the inspection hole in the bellhousing. Either that or dopping the trans, either way it sucked.
Re: guess these vehicles don't like high water [Re: Jamez] #1025500 03/28/11 01:27 AM
I'm glad that I've got an automatic. I've had mine in that deep of water, and my problems seem to be electrical from the fan throwing water on everything electrical.
Re: guess these vehicles don't like high water [Re: Mudraider] #1025501 03/28/11 01:31 AM
Maxximtl Offline
I'm thankful that my Monty leaks so much oil. Everything is encased in a hydrophobic sarcophagus that eliminates any potential water failure.
1992 Montero SR
Re: guess these vehicles don't like high water [Re: Maxximtl] #1025502 03/28/11 02:30 AM
0778drz110 Offline
Water is bad, avoid at all times.
Re: guess these vehicles don't like high water [Re: 0778drz110] #1025503 03/28/11 04:33 AM
StockRaider Offline
Ive had water over the hood several times for a decent amount of time (driving through floods) and not a single issue, I also have an automatic I sealed off so that might be the key difference.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: guess these vehicles don't like high water [Re: StockRaider] #1025504 03/28/11 05:28 AM
ryany Offline
I accidentally drove my Montero through 4 feet deep salt water, but had no problems with the starter. The salt water in the valleys between the cams caused the ignition system to short out, but no starter problems. The water in the cabin completely shorted out the power seat relays and motors, the power door lock solenoids, the locking rear differential air pump, CD changer, and the ABS control module, but no starter problems. <img src="/forums/images/graemlins/lol.gif" alt="" />
95 Montero SR
Re: guess these vehicles don't like high water [Re: KrzyDav] #1025505 03/28/11 05:54 AM
belijose Offline
I have been trying to relocate the ecu on my 89 raider but the wires aren't long enough. How and where did you put it?
1989 Dodge Raider v6 3.0 L, MT.
Re: guess these vehicles don't like high water [Re: 0778drz110] #1025506 03/28/11 06:33 AM
3
300D50 Offline
Bah, you simpletons with "ECU's" and "ignition systems", if you all had Benz diesels you'd be driving through it like nothing! <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
I need a snorkel now... just because...
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6459 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-05-29 14:43:16 UTC
