AC/Heater blower issues #1025837 04/01/11 02:21 PM
TexJeff87 Offline OP
I smelled that burning-ozone kind of smell, and the blower quit working. Is it the switch, or a relay? The low setting on the switch did not work already.
If Mad Max had a 4runner...
Re: AC/Heater blower issues [Re: TexJeff87] #1025838 04/01/11 03:33 PM
4Crawler Offline
Might be the motor as well, worn brushes perhaps:
- http://www.4crawler.com/4x4/CheapTricks/Blower.shtml#MotorRepair
Since the switch is probably the hardest thing to get to, I would probably check everything else (motor, resistor pack, relay) and if all that is OK, then the switch last.
Re: AC/Heater blower issues [Re: 4Crawler] #1025839 04/02/11 03:45 AM
P
Pyroboy Offline
If you lost low speed, then medium speed, I would agree it's likely the resistor pack, but it does not control high speed. If it's the motor, you can pick up a replacement for about $40 and switch your fan over. I think mine is a Siemens. It was simpler than trying to swap the brushes.
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
Re: AC/Heater blower issues [Re: Pyroboy] #1025840 04/04/11 01:54 PM
I pulled the one out of the wrecked truck, it works great...low speed still no go, so I'll have to check the relay.
It's already getting hot down here, so having the AC back is a huge plus, low speed or no.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6048 MB (Peak: 0.6606 MB) Data Comp: Off Server Time: 2026-05-29 23:49:06 UTC
