4D56 Injectors - Cross-reference # ? #1025894 04/03/11 01:15 AM
O
Orionsbelt Offline OP
Has anyone discovered the cross reference number for injectors?
If someone has made a timing belt kit I'd be surprised if there weren't injectors...
I came across a set of zexel's on eBay...fairly inexpensive...
Thoughts..?
Re: 4D56 Injectors - Cross-reference # ? [Re: Orionsbelt] #1025895 04/08/11 06:52 AM
torquemonster Offline
yeah there aren't any different brand of injectors available, OEM is the only way to go, which is Zexel.
Re: 4D56 Injectors - Cross-reference # ? [Re: Orionsbelt] #1025896 04/09/11 06:04 AM
redbull Offline
I still have a set of Zexel's I bought on ebay when I first got my Paj. Came from Australia.
Re: 4D56 Injectors - Cross-reference # ? [Re: Orionsbelt] #1025897 04/09/11 03:44 PM
Glock24 Offline
Why do you want to replace the injectors?
Injectors are supposed to last forever, you only change and calibrate the nozzles at a diesel lab.
When you remove the injectors you need to replace the copper washers that act a as seal between the injector and the cylinder head.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
Re: 4D56 Injectors - Cross-reference # ? [Re: Glock24] #1025898 04/13/11 02:12 PM
Bolt_On Offline
Cord at Sun Diesel Systems is getting me nozzles ($35 ea), a shim kit ($9), and washers ($10?) from their Australian division. Complete injectors would be $85 ea.
http://www.sundieselsystems.com/
'89 Raider Diesel, ARB front, '96 Montero SR disk/locker rear axle & front brakes, 2.5" ss exhaust.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6048 MB (Peak: 0.6690 MB) Data Comp: Off Server Time: 2026-07-09 14:13:37 UTC
