4D56 Injectors - Cross-reference # ?
#1025894
04/03/11 01:15 AM
Has anyone discovered the cross reference number for injectors?
If someone has made a timing belt kit I'd be surprised if there weren't injectors...
I came across a set of zexel's on eBay...fairly inexpensive...
Thoughts..?
Re: 4D56 Injectors - Cross-reference # ?
[Re: Orionsbelt]
#1025895
04/08/11 06:52 AM
yeah there aren't any different brand of injectors available, OEM is the only way to go, which is Zexel.
[Re: Orionsbelt]
#1025896
04/09/11 06:04 AM
I still have a set of Zexel's I bought on ebay when I first got my Paj. Came from Australia.
[Re: Orionsbelt]
#1025897
04/09/11 03:44 PM
Why do you want to replace the injectors?
Injectors are supposed to last forever, you only change and calibrate the nozzles at a diesel lab.
When you remove the injectors you need to replace the copper washers that act a as seal between the injector and the cylinder head.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
[Re: Glock24]
#1025898
04/13/11 02:12 PM
Cord at Sun Diesel Systems is getting me nozzles ($35 ea), a shim kit ($9), and washers ($10?) from their Australian division. Complete injectors would be $85 ea. http://www.sundieselsystems.com/
'89 Raider Diesel, ARB front, '96 Montero SR disk/locker rear axle & front brakes, 2.5" ss exhaust.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6041 MB (Peak: 0.6683 MB) Data Comp: Off Server Time: 2026-05-29 16:15:42 UTCValid HTML 5 and Valid CSS
