1998 trooper needs new windshield washer pump #1025921 04/03/11 03:03 AM
monkey Offline OP
OK, So I have my new "JCWhitney" Washer pump. I can SEE the old pump behind what appears to be a vacuum pump device ? and through a cut out in the fender. I have peeled back the fender liner but still can't figure out how to get at the pump. Do I take out the washer reservoir? and if yes- HOW?
any of you guys ever do this task? Any advise will help and thanks in advance!
Now I know why the dealership wanted $200 bucks to do it!
Re: 1998 trooper needs new windshield washer pump [Re: monkey] #1025922 04/03/11 11:16 PM
Van Offline
Click on the following link and in the upper left hand corner where it says "Part # Search", type in 8-97807-510-3
http://www.myisuzuparts.com
Click "Submit" and then on the next page, click on the camera for the Trooper on the 3rd line.
Looks like you'll have to remove #'s 116, 27, 42C and the electrical connector to the pump to pull the tank out... #116 and #27 are probably in the fender well.
A pretty easy task... just be careful you don't lose #25. <img src="/forums/images/graemlins/scared.gif" alt="" />
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: 1998 trooper needs new windshield washer pump [Re: Van] #1025923 04/03/11 11:36 PM
monkey Offline OP
Van,
Thanks! I ended up never being able to get to the screw holding the front end of the reservoir (what was Isuzu thinking?). Using an assortment of extentions, a pair of 20" forceps, a few choice words and three advil... I managed to get the old pump out and new pump in. Yeah! after 2 years we have a functional window washer...
I moved on the 4x4 SOTF constantly blinking indicator issue. As per the posts I took off the vacuum SOTF actuator. About a half cup of really nasty fluid drained out. I could not get the "arm" to move via hitting the switch nor could I get much of a read on vacuum intensity inputs. It does make noise when I SOTF button is engaged and disengaged. I put it back and now the light does not blink when SOTF is in off position but now blinks when in the on position and still have no 4X4.... And I ended up hearing a fairly loud clank and what seems like a chatter coming from the hub so I'm about to bite the bullet and take it to the dealership for some spend some $$$$...
<img src="/forums/images/graemlins/confused.gif" alt="" />
"tryin' to squeeze 220K out of the old trooper"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5947 MB (Peak: 0.6486 MB) Data Comp: Off Server Time: 2026-06-07 06:08:10 UTC
