87 Raider Connector Question #1026019 04/04/11 04:08 PM
W
willwinchforfood Offline OP
Does anyone know what the black connector with the black with white stripe wire located just aft of the coil connects to? This connector breaks out of the harness about halfway down the wheelwell right by the coil and is only about an inch long.
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: 87 Raider Connector Question [Re: willwinchforfood] #1026020 04/04/11 05:31 PM
That's so stupid. Why don't you download the manual and look it up? Can't you use the search function? Dang newbs...
The 2BW wire shown in the wiring diagrams and harness diagrams goes to the coil ballast resistor bottom terminal, to power the coil in ign run position. This is a fairly fat black/white stripe wire. The connector on the end of the wire shows in the diagrams the same as the 2BR wire that goes straight to the coil + or top of the ceramic resistor for dropped coil voltage during ign start position. THe 2BW wire should be hot at ign run, dead at ign start, and dead at off and acc (I think).
Look at 8-36 and 8-38 and -39 in the 87 fsm, also look at the engine compartment harness diagram second page for possible other suspects. The connector number on the harness diagram is the same as the connector number on the wiring diagram, a43 I think. Legend tells you what the connector is for. Harness diagrams are just before the wiring diagrams, and engine compartment is one of the first ones.
Re: 87 Raider Connector Question [Re: fasteddy] #1026021 04/04/11 06:44 PM
W
way to short to go to the coil.
Re: 87 Raider Connector Question [Re: willwinchforfood] #1026022 04/05/11 02:10 AM
philCA Offline
It connects to a wire lead from the AC compressor clutch.
1987 Raider 2.6L 5 spd w/ LSD off road package 130K miles
1987 Conquest 2.6L 5 spd w/ intercooler 56K miles
2000 4Runner locking RA 34k miles
Re: 87 Raider Connector Question [Re: philCA] #1026023 04/05/11 03:51 AM
W
Dang it then that leaves another connector. I'll get a photo tomorrow. The compressor is not installed yet.
John
Re: 87 Raider Connector Question [Re: willwinchforfood] #1026024 04/05/11 04:27 AM
You might try checking that wire for voltage when the ac switch is on, but you may have to short around the low pressure limit switch in the ac lines somewhere, pside core support maybe, to get power to that wire - it's at the end of a chain of relays and various safety switches (I think it shares the tranny od ground temp switch as one of the relay coil grounds). including the fan switch, too, in the compressor clutch power path.
On page 8=57 look at connector a45, also on the harness illustration on 8-29. It's a hair smaller than average .85BW wire, too. Note it's power path on 8-57, from the ac relay thru the low limit switch to power the magnetic clutch, the condesor blower relay, and the condenser blower. a45 looks like it breaks out of the wire bundle that has the wire for all the water temp gizmos, maybe 5" back on the bundle.
Look in the fsm at pages 8-29, at connector a40, listed on page 8-28 as condensor fan motor relay. Thats the fan infront of the a/c condensor/radiator, and I think it's relay is thereabouts.
Re: 87 Raider Connector Question [Re: willwinchforfood] #1026025 04/05/11 06:31 AM
philCA Offline
Looks like A-45 to me as well. Went out and looked at wiring. The BW from the clutch connected to A45 clamps to the top of a compressor and goes to the clutch as the wire closer to the vehicle center line. The other wire at the clutch, closer to the fender, is the ground wire and is also clamped to the compressor. I haven't traced the ground path.
Re: 87 Raider Connector Question [Re: philCA] #1026026 04/05/11 01:16 PM
W
I didnt realize there were two wires on the compressor. That would be what the other connector is for then.
Thanks
Re: 87 Raider Connector Question [Re: willwinchforfood] #1026027 04/05/11 05:26 PM
as we do the victory dance...
any progress on the misfire? I think I have a 2.6c drivability fsm somewhere. I'm out of ideas. lets newpost it here.
Re: 87 Raider Connector Question [Re: fasteddy] #1026028 04/05/11 05:56 PM
There you go FE. Teach these children right! <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6315 MB (Peak: 0.7401 MB) Data Comp: Off Server Time: 2026-05-29 20:00:44 UTC
